I am very new to turning, mainly small boxes at this point, hopefully some small bowls in my future. I want to start power sanding. I have one of the cheap HF right angle drills but want advice on the discs and holders. Best place to order from? Your help is greatly appreciated.
The most commonly used sanding disc suppliers are;
Steve Worcester at turningwood.com
Vince at vinceswoodnwonders.com
Bruce at thesandingglove.com
I've bought discs from Vince and Bruce in the past and will probably buy from Steve in the future.
As far as which discs? You'll get several recommendations. One thing that does hold true, "you get what you pay for". I've changed disc brands from time to time. I do like the 3M and high end Norton discs that Bruce sells at thesandingglove.com. They're more per disc but outlast the other discs by a landslide. I do want to try the Mirka discs when I reorder next time.
..blue plastic backed discs, and his backing pads and the intermediate radiused pads are money savers as well. I suggest that you order 1 of his starter kits, then you will have samples of the entire set-up to test.
Sandpaper should be used like someone else is paying for it. Sandpaper that last a long time might appear to be a good value. But sandpaper that cost very little will help insure that you discard after use.
The holders sold by Industrial Abrasives are excellent and cheap. 2" holder for $5.50
The sandpaper discs 2" and 3" are of good quality and inexpensive. 25 2" discs for $5
The sandpaper disc at sandpaper.ca are also a bargain. 30 2" discs for $5 Canadian
I have used the blue discs from Vince and they work great. i have also used the Abranet discs which work wonderful. The Abralon discs give a sensational soft feel to the workpiece.
You will melt the plastic hooks of the sanding mandril as you learn power sanding. The benefits of the more expensive sanding mandrils may be lost during the learning curve. After you become proficient at power sanding your mandrils will last a long time and high dollar sanding disc may be worth while.
Another vote for Vince's discs. I tried the Mirka discs, and could get the outside of one 14 inch bowl with one disc, but it was pretty much shot by the time I got to the inside. I tried the Norton Dry Ice discs from the Sanding Glove. I could get a 3 bowl cored set of Myrtle wood bowls with one set of discs. They were almost done by the time I got to the last bowl, but since the last bowl was small, it was effective to keep the disc on. I got the same results with the discs from Vince on another set of Myrtle wood bowls the same size, and from the same tree. The Norton discs are not quite 3 times the cost of Vince's discs. I do turn green to final thickness, then do the LDD (liquid dishwashing detergent) soak which makes bowls a lot easier to sand out. Vince's discs, and the Norton discs can feel dull to the touch, but if you watch to see how much dust is coming off, it will still cut very well. I do keep the eraser stick handy.
Most important things I have learned about sanding:
Slower drill speeds cut better than higher speeds. I never go above 600 rpm, and most of the time am much slower than that. Since my bowls are warped, lathe speeds are in the 10 to 15 rpm range (Robust American Beauty which Brent English helped me adjust the minimum rpm speed down).
Light pressure means the weight of the drill is max. Any more and you start to heat up the wood, and burn off the hooks on your pads. The slower speeds help the discs last longer. The slower speeds help the drills last longer. I use the Milwaukee/Sioux drills, and used to get about 300 bowls before the bearings were shot. Now I get 400 to 450 before the bearings need replacing.
Buy a good mandril or 3, and some interface pads. That way you wear out the pads which are cheap instead of the mandrils which are expensive. I prefer a firm pad, especially the ones from Vince which have a 1/4 round profile on the edge. This is much better for the inside of the bowl than a square edged pad. Soft pads only for the higher (220 and above) grits. 120 grit on a firm pad cuts better than 80 grit on a soft pad. Most of the time I keep the firm disc on through the whole progression.
Thank you for your post. If you need samples of my discs feel free to contact me at 1-877-284-8969 and I will send you samples. I have a new discs that many people have not tried. It's called Cera~Max discs and it has a mix of ceramic and A/O. More ceramic in the lower grits and then blends to more A/O in the higher grits. These discs are outstanding!!! Feel free to contact me.
You'll probably want to buy a starter set from some place like those posted above. But once you get into power sanding and start to know what works for you, you may want to buy in bulk to save some money. One of the best things that I did years ago was to buy several large sheets of various grits (100, 180, 220, 320, 400) from Industrial Abrasives and then cut my own 2" disks to fit my backing pad.
To cut the discs, I bought a cheap 2" hole saw and ground the teeth off on my bench grinder and sharpened the edges and mounted it on a Maple cylinder. Then I placed the sandpaper sheet on a piece of scrap plywood and punched the discs by hitting the "punch" with a mallet. I cut discs from half the sheets that I purchased several years ago and I'm still working through my supply. The initial cost was relatively steep ($75 + shipping) to get started but it seemed a lot cheaper in the long run than buying pre-cut discs.
You have given me some great advice. I mainly just lurk here and try to absorb all of the information that is so freely given. Thanks Ellis for bringing together an incredible group of people. Vince thanks for the generous offer, but I think I will just place an order for your starter kit today.
What I would like to have is a mandrel for each grit. I would look for disks that have hex shafts with the cove around them to allow the use of the quick disconnect coupling. then I would set up a board with a row of holes for the mandrels or some other rack.
I find that pealing the hook and loop sandpaper off repeatedly wears out both parts and they don't stick well. So having multiple mandrels allows you to leave the sandpaper in place until it wears out and it allows the mandrels to cool while you switch to the next disk.
You can do this with mandrels that don't have the quick change, but it a little pain in the butt.
I have no experience with the high end sandpapers, but they are worth looking at. I would have to be really impressed. Think about buying the Industrial Abrasives sheets and cutting your own. You can either cut them with a "cookie cutter" made from a cheap hole saw or just use an old blade on a bandsaw and cut them into squares. You will get used to the corners and find them harmless or even useful. The cost is vastly lower than disks. You might find a fellow turner or two and share the cost, because its easy to make hundreds.
Also worth looking at are the pads that you add to the mandrel. Then you can change them instead of buying a new mandrel.
Barry I went with individual mandrels for each grit for exactly the reason you mentioned. One of the best investments in money and time I have made. I went with the hex shafts but found I never use the adaptor. It's not that big a hassle changing mandrels with keyless chucks and they don't accidentally fall out like I have had happen on the hex adaptors. I still like them because once in a blue moon I will use an extension on my mandrels.
Really, they are all good products. Vince's, Bruce's, mine. We all have something a little different, but they are all good products (and I have used them all) .Get some samples from any of us, I think most of us would send a free sample pack, and use what works for your style and wood types.
I am really partial to the mandrels I sell from Skilton, I think they are the best. But nothing stops you from gluing a piece of Velcro onto some wood with an embedded bolt, and using interface pads to make up the level of cushion you need for that piece on the lathe.
Any right angle sander will work, just different levels of quality and durability (and noise). Keep the speed low, sand in the direction that works for you, I prefer the pad sanding in the direction of the wood when you want less aggressive stock removal, and in the opposite direction when you want more aggressive.
More importantly, work through the grits and don't jump grits in the name of expediency, it will only cause problems. Each grit is increasingly smaller "pebbles" to eliminate the scratches from the previous grit, so skipping won't help.
Go up to the level you need for the finish you need. Maybe 320-400 for an oil finish salad bowl, same or so for a piece you are going to spray, or up to 800- or higher for a piece you want to buff.
Some folks like to punch out there own discs by mean you described and that is great. For some time and convience comes into play. FYI, if you are interested I have 2" discs 100pk lasered out and ready to use for $10 and I would put them up against anything Industrial offers. Samples available! Thanks, Vince
..clouds of sanding dust, give good attention to dust control. You should not underestimate the potential harm breathing dust can do to your respiratory health.
....that I picked up here for a steal . My next big purchase is a dust collector, but I want to have in a bump out on the outside of my small shop for the noise and stuff that gets through the filter, so its going to take some planning and saving. In the meantime I found that my big, quite Ridged shopvac works great with the exhaust ported through the wall.
