filling pores in burls
Tom Sontag - St. Louis
I ask this for some flat work, but I figure you folks are the experts I want to hear from. Aren't there some times when you go for a completely smooth look?
I've got some aussie burls I am making some thickish veneer from, maybe 1/16" or so. Red mallee, bimblebox, coolabah, etc. Especially the red mallee seems to have some failry large voids (not as big as gum voids) that I would prefer to fill with something so the substrate does not show through. Epoxy is always a possibility, but not the look I want. No way for powdered turquoise or any of that stuff either. I wondered if wet sanding with shellac would A) fill them, and B) color match well enough to become invisible.
Any suggestions on what else I might try?
Re: filling pores in burls
Steve Kubien
Steve Kubien
What if you mixed dust from the veneer species with epoxy? My concern with the shellac-method is that shellac can be easily damaged, especially from alcohol spills.
Sorry, it's the best I've got.
Doug Trembath
I presume you're bandsawing the veneer, right? After you place the veneer, before final sanding, collect some of the sawdust, mix it with shellac, epoxy, or even the final finish you expect to use, to create a filler. Plunk it in there and let it set up, just like regular filler, then level it with sandpaper. If there are bark edges, look for some similar material, like dark walnut, or use coffee grounds if they will provide a good color match, and make some from that. Of course, there are many options to color it as you please, as well. You're probably familiar with that.
I've been successful with this routine many times. (I don't mention CA glue, because I just don't like it, for one, and don't trust the durability nor the reliability over time.)
Let us know if you try it, OK?
Doug Trembath
