Anyone know a source for a small cup center with a 1/4" diameter cup? I know they exist, or used to exist because one of the chisel handles I am replacing clearly shows the imprint of one on the end of the tenon. I would like to find one, because using a conical live center results in the end splitting even with considerable care.
It's not cheap but the Nova live center has a cup center as part of the accessory tips. It's not 1/4" I'd say it's more like 3/8 or 1/2".
If you want to limit the penetration of your cone point just put a small washer on it. The size hole in the washer will limit how far down it goes on your cone point. I have really tiny washers that limit penetration to about 3/16". Washers with larger holes will let the tip go in deeper.
If you have a live center with interchangable tips, couldn't you make one out of some copper or brass tubing and a bit of wood? No law that says it all has to be metal?
I made these for my Oneway Live Center, a couple of weeks ago using 3/8" CRS held in #1 jaws in a Oneway Chuck. Taper approximated using angle grinder then fine tuned with a Co HSS scraper (Oland type tool) I have made plus some 1/4" Co HSS held in Vice Grips. When conducting a Hands-On in my shop three weeks ago, Cindy Drozda mentioned that Bruce Campbell in Vancouver has these for sale. My tapers are not perfect, but they seem to work fine. Cup centers were drilled using a 60 degree centering bit held in a Jacobs chuck in tailstock.
I've got two Multistar Live centers, and I absolutely adore them! The Micro 32 is my favorite, since it has components for every project. (Also has make-your-own center backing plates.)
I also have the system that Craft Supplies sells -- the primary difference between the two is torque...
The CS system is like a typical live center system, where the large holder revolves around the shaft.
On the Multistar Micro set, the bearings are inside the holder, so it generates MUCH less torque.
Of course, your project is going to dictate if this is of any importance to you. (Personally, for long thin things, I like less torque -- prevents breakage!)
If torque is not an issue, the CS system is also a pretty good one with lots of small tips. However, I find myself persistently reaching for my Multistars...
I also used a file to dress the taper after using angle grinder and Co tool piece, followed by sanding with a 1/2' wide strip of 400 cloth backed paper. There is about a 1/4" straight section to allow chucking in the #1 jaws while working on the tip. Total length varies from 1 1/16" to 1 1/4". The cup is 1/4". Cutoff disk in angle grinder used to cut to length. First one took a half hour to make, the last one about 10 minutes.
I have been purchasing MT2 adapters for drill chucks (JT tapers) and cutting off the excess lenth as the Nova uses a short section of MT2 taper for the inserts. Just cut with a hack saw and scrap out the portion smaller than needed to fit into the live center -
I use the headstock taper hold the adapters on occasion and use a HSS metal lathe bit to cut/shape the final end before bobbing off the tail end.
Have not made the tiny cup center -- but center drill for the cup center and lathe filing for the outside will get you there fast.
I get the adapters on sale from little machine shop or other vendors and keep a few on hand. About $4 on sale, so easy on the pocket book to experiment.
Thanks very much for this tip. A friend is turning some cup centers for me, but in the mean time, this works well, as long as I don't drop them in a pile of shavings!-) when I am changing the piece.
