I've been working on our club lathe which is a Nova 3000. I replaced the bearings. It's running smoother but still has a problem. It has leeson DC motor and Leeson controller. When you start taking anything bigger than a fairly light cut it starts bogging down and has a rythmic hum and power surges. I'm guessing its the controller but how would you tell. I don't currently have a spare controller or DC motor to play with. I'll probably try and contact Leeson later today but this was quick and easy. I have another assignment walking in the door so back to work.
Only guessing from >500 miles away..... I have not worked on this lathe or with his specific motor/controller combination, but to me it sounds like there may be something going wrong with the speed sensor feedback to the controller board. As force is applied against rotation with your cut, and the spindle speed slows, the controller should read a signal, detect the slowing speed, and supply more current to the motor to maintain speed/torque that eh lathe is set at. Perhaps something is happening in this part of the speed feedback loop?
If you have a diagram or schematic, you might check where the speed is being sensed (via a phototransistor, magnetic sensor, etc.) and be sure there are no connection problems between this device and the board, or there is no accumulation of gunk (a technical term) in or around the sensor (often adjacent to the spindle somewhere).
If this doesn't resolve the situation, I would start doing some voltage checks on the circuit board if you have the experience to do so. It may be possible to locate an open/fried component in this way. Whole-board swap-out might be rather costly.
I have a DVR and it has some sort of internal sensor that watches the shaft and adjusts the speed. You have to blow the dust out of it when necessary. Maybe they used similar technology on the 3000.
The controller is different on the DVR and Leeson. I sold my 3000 with the Leeson but I remember there are several resistors on the circuit board that can be adjusted. I gave the Leeson manual to the person who bought it so I can't give you specifics. You have to adjust them with a non magnetic screwdriver as I remember. One specifically does sense and adjust torque.
Look at the adjustments inside the DC drive. If there is one marked IR or IR Comp, make a picture of where it is set, then try adjusting it up and down. I assume you've checked brushes. If not do that first, and blow out any dust around the commutator.
Well I finally got off work after coming in at 6:30 this morning. The brushes are the first thing I'm going to check. The leeson website had a problem check list. It doesn't have any external sensors for speed so that's out. I was wondering about some resistor adjustments. If I remember correctly my first DC controller had something like that and I was able to change it. That was a long time ago. I'll look tonight.
I did talk to my local motor repairman and he said he could fix whatever is wrong. It's just finding out how much so i can tell the club and we make a decision.
thanks for all the input. I'll go home and play for a few minutes. Tomorrow is going to be another 12 to 14 hour day so I need a little rest.
About 4yrs ago I had some problems with my Leeson Control could not remember where I put my Controler Manuel went to their Web Site and was able to download the pages explaining what to adjust on the pods. I looked up my model which mine was and fixed the problem. Maybe this will help you.
Thanks Bill I'll try that if my local motor shop is too expensive. I would think if the fix is that easy they would take care of it at a reasonable cost.
