Jennifer, some other tools...
Leo Cuellar
that you might find of use are these doming punches & block. They were about $35 at Harbor Freight & not too bad of quality.
You'll probably find the punches of greater utility than the block, as have I, but it might make a nice paperweight.
A lot of sheet metal tools were made of hickory & hickory faced with leather. I was playing around with some soft wood...
And made a couple of simple blocks to form some copper with...
I pounded out the bowl of the spoon in the carved hollow in the block with the punches & smoothed it out on the turned stick with an old Rosewood "potato masher" mallet.
and this is my first try at a copper spoon. Made from a section of 3/4" pipe for the bowl, with a tang left on it. The shaped & brass pinned ferrule was made from 1/2" pipe. You can't see it in the picture but the ferrule comes to a point & overlaps the bowl of the spoon inside & out. The handle is Catalpa. It was fun trying to figure out how to do this, the next one should be easier.
It is great that Bellingham ended up with a HF walk in store somehow. It is handy to be able to see if what you're considering is a chunk of junk or not.
