This is a snare drum I finished today. This is a "standard" size snare drum which is 14" x 5 1/2".
The drummer from a band called 10,000 Maniacs is a friend. Haven't seen him or the band for many years. They are doing their 30th anniversary tour this year and the middle of next month they will be performing close enough for me and my daughter to go see them.
I learned a lot in making this drum. The drum shell was simple. The other parts are also fairly simple but something new for me. The new parts were more than a little daunting.
The shell is 8 stave curly maple with cocobolo accent strips.
What about wood hoops? There is time to make wood hoops and the look of wood hoops can be quite spectacular.
What about the sound? The drum sounds like a drum. I wouldn't know the difference between a lousy sounding drum and a great sounding drum. I do know that there are folks making drum who have a LOT more experience than I have. I suspect that there is a lot to learn to make great sounding drums.
Looks great to me, but I know nothing about making drums, or drumming. I did see one of htose TV shows on how they make things and they made a snare drum by rolling veneer into a circle and laminating it, they they cut a scarf joint in it and glued it up into a cylinder. I wonder if that woudl change the sound? either way, its a beauty.
Some drums are left really rough on the inside and that changes the sound, but I don't think that is a snare drum.
Different materials and different construction techniques have different impacts on the sound and playing characteristics of the drum.
Most drums are laminated like you saw made on TV. They have a high percentage of glue compared to the other construction methods. The laminate method lends it self to factory production more so that stave or solid wood.
The less glue the more "live" the drum is supposed to sound.
The inside of the drum shell should be smooth. A rough inside is to be avoided. The most important part of the shell is the "bearing edge". That is the part of the drum shell which is in contact with the drum head.
Very cool, Richard! I'm gad you know about the bearing edge, that is quite important. Looks like you did some homework. The throw-off (or strainer as some call them) can compensate for some of the bearing edge sound also. I didn't see a muffler on this, did you put one in? Proper tuning is really what it's all about and I bet this sounds great. I've been playing all my life and even sold vintage drums for a living as my own business till the economy killed it. The maple was a good choice, nice sounding wood and the figuring makes it a looker. Your buddy would love to see and play this.
I thought about a dampener. I suppose I could still put one on. The literature talks about a smooth inside to the drum. With all the bolts holding the lugs, strainer, butt end and vent it seamed like there was more than enough for turbulence. The dampener I saw would add a lot of irregular surface for turbulence. I guess I am over thinking that part
Should I put in an internal dampener?
I am thinking about making wood hoops. Primarily the wood hoops give ma a chance to add some more turning to the project.
The drummer plays in a lot of different bands so I suspect that his skill and range can make most any drum sound good. But I wonder a little about difference between wood hoops and die cast hoops.
If the drum sounds really hollow (a lot of echo), you might think about a dampener, but there are ways around that also. They make thin rings (maybe 1") that look just like the drum head that sit right on the drum. They have a catchy name like "ring things" or something. The name escapes me right now. They make external dampeners also, they attach to the rim. A "black dot" head will also help. Any music or drum store should have these. Many drummers also put tape on the head, but they would have to be shot for messing up such a nice drum. lol.
If you do put one in, the extra hardware inside the drum really won't matter, there are a lot of pieces in there now anyway (as in any drum). If you do decide to put one in, some of the best sounding snares out there are the old ones and they have dampeners. Gretsch used to have them on both heads!
As far as the rims go, I wouldn't go through all the trouble of making wood ones. The chances of them cracking are pretty good and warping is almost inevitable. They also go out of tune quicker. Die cast rims are great.
Anyway, if it were me, I'd leave the drum as is and try the "ring things" if you think the drum sounds too hollow or tinny.
I wouldn't know hollow sounding if I heard it. In fact the whole tuning of drum thing is a total loss for me. I guess I need to take the drum to a music store to get the drum tuned.
Thanks especially for the info on the wood hoops. I imagine this drum spending a good deal of it's life sitting on a shelf. Actually I intend to make a swinging leg stand and a wood cover (lose table top) for the drum so it can be used as an occasional table. I would hate to spend the time and effort on making wood hoops only to make the drum less appealing to be used because of the tuning needed on the rare occasions the drum was used.
That looks nice, Richard. My son is a professional percussionist, currently getting his Phd-a Dr. of drumming.
He has many snares, and I have worked on several for him, either modifying hardware, or changing the snare beds. I know nothing about it, but just follow his wishes-I have the tools to work on the metal as well as wood and composite drums. I never realized how many kinds of snares there are, but orchestral snares are quite different than marching snares etc.
What are you going to make next? I wouldn't mind doing some marimbas. Max Krimmel in Colorado has made quite a few ethnic type marimbas etc.
Thanks for the kind words. I hope my drummer friend likes the drum.
There are loads of different snare drums. Some are very tall and some are very short. I exchanged e-mail with my drummer friend to find out what the basics of the snare he likes to use and the drum heads he likes.
Making stave rings is one of my favorite turnings. I make canisters and occasional table aprons as stave rings. As well as tapered stave burial urns. So a stave drum shell is in my ball park.
I had to look up marimbas. Wouldn't wood tubes have a terrific sound. Different lengths, different diameters, different wall thickness, different woods. The look with different woods could be quite striking. Maybe a few experiments, work up a plan and get it started on my list.
There are lots of different designs for Marimbas. Some use gourds for the resonate chambers. Many use metal tubes. PVC is used in some Marimbas. The resonate chambers are sized for resonating a specific sound, usually notes like a keyboard are specified.
Bringing the drum to a music shop to get the drum tuned would be a great idea. They can adjust the snare wires for you also, which is another critical part of the sound. The marimba's are a cool idea. You can actually tune them to play a melody. An unexpected sound to come out of drums. Good luck if you decide to do it. I'd sure look forward to seeing those!
I just got back from the music store. One of the guys at the store tuned my drum. They talked me out of any dampening. They were very impressed with the look, sound and action of the drum. After tuning they played the rum for a few minuets and managed to draw a bit of a crowd. Everyone said nice things about how the drum sounded and how it looked.
I am going to make a second snare drum as a "sample" to see if there is any interest in my "fine looking and fine sounding" drums.
Anyway the whole thing was very heady and I am grinning from ear to ear.
That's great news! Glad it all worked out OK. Did you buy a pair of sticks? You might want to do a little practicing on that beauty. Have fun and good job!
Sticks are ROUND which are going to be included with the drum. I have made drum sticks (B5) for my friend before. I will be making sticks for this drum as well. I plan on carving and coloring in some lizards onto the non-business end of the sticks. I know the carving will make the sticks a LOT less useful but he has loads of drum sticks so he will think the lizards sticks look cool. And the sticks will be able to beat on the drum for a "test" when I present the drum.
