Anchorseal source and price?
Ricc havens
What's the best source and price for Anchor seal in gallon cans? Or if you use another brand of sealer at a good price please let me know
Thanks
Ricc Havens
Ricc havens
Thanks
Ricc Havens
Re: Anchorseal source and price?
Google UC Coatings and check out their price on Anchorseal
That's where I get mine.
steven antonucci
Buy it in 5 Gallons and it's pretty cost effective. I probably bought mine 6 years ago, gave away 1/2 of it, and I still have a gallon...
S
Katherine Kowalski
Hi Ricc,
I belong to two clubs, and each has a different solution for getting end-grain sealer at less cost than retail:
The Rocky Mountain Woodturners buy a 100 gallon drum. We have a pump to dispense it into containers members bring themselves. (Usually plastic milk jugs). With this type of bulk buying, we charge members cost -- $9/gallon.
The Front Range Woodturners do a group buy twice a year, each member gets sealed cans for $19.99 each.
I believe the retail price for Anchorseal is something like $32 in this part of the country, so the clubs' group buying power saves us a lot of money.
It may be worth investigating setting up something like this in your own local club.
Katherine
Our club (meaning me) bought a 5 gallon container and split it up. It came to about $20 a gallon I think. At that time Woodcraft was selling it for about $24 I believe.
Most of my smaller blanks I now seal with Parafin wax by dipping them in an electric skillet with melted wax. That has saved me quite a bit on Anchorseal. I usually try and coat the ends of logs when I first get them. After that I try to cut them up into blank sizes and seal the end grain with wax.
I still use the Anchorseal to seal end grain areas of roughed out bowls. It seems to cut down on my loss.
Jeff Rich
I bought 5 gals last year direct from UC and I believe it was $67.00
That amount will last about a year.
Jeff Brockett
A bunch of us purchased a 50 gallon drum and divided the cost up. Price was about $10.00 a gallon. We did have to go to the truck terminal to pick it up.
Buy direct-UC Coatings
Greg Haugen
UC Coatings is the manufacturer of Anchorseal, Anchorseal2.
A 5 gallon pail will cost $66 to $74 depending on how many and shipping is free eastern states. I usually buy 2 five gallon pails when I order. One for me, and one to sell to club members by the gallon. I don't make any profit. The Shipping is free for me and I get the price break for 2 buckets.
https://www.uccoatings.com/Home/WebStore
Or get your local club to buy a drum and offer it to members.
Jorge Casta�eda
I bought a 5 gal can about 4 years ago around $60.00, I still have a third. ask for the winterized version. Or just explore their site: US Coatings.
Emmett Manley, Lakeland, TN
Go to the paint department at Lowe's (and sometimes, Home Depot) and ask them if they have any mis-tinted paint for sale. They nearly always do. Top quality paint, normal price of $20-25 a gallon and you can get it for $5.
The purpose of paint is to keep water out, so it is also excellent at keeping water in, or letting it out slowly during the drying process.
If you have fallen for the advertisements and believe Anchorseal is better than a good paint, run your own tests.
walta
At my club we sell it 2 gallon for 30.00
Walta
jim miles - Charlotte
Agree- latex paint- the purpose is not to seal in the moisture- be to slow it down - you want it to dry
Paint works fine
Did not work for me. In fact I tried putting on 3 coats. 2 coats of Anchorseal works better in my opinion. In fact I tried a lot of things. PVA glue worked but was too expensive. Roofing tar worked but was way to messy. Caulking too expensive.
I forget all the concoctions I tried. By the way, the cheaper milk jugs don't work to hold Anchorseal. I don't know what it is about them but I everyone of them develop cracks and leak. I found chemical bottles and bleach bottles work better.
During all my experiments I found that the #1 thing you can do to slow down the checking is get them out of the sun and weather. Since I can't do that I set them on end. The wet ground slows down that end of the log. Then I only have to coat one end. If I don't have time I will put plastic garbage bags over that end. Those work for a month or two before the sun deteriorates them. By then you should have time to cut them in half and seal the ends of cut bowl blanks out of them and seal the whole thing.
When I leave bowl blanks with only the end grain sealed I almost always lose them unless I can get them roughed in a few months. Sealing them with wax completely has saved some for years. I've been running long term tests on the wax. I can save vessel blanks with just the ends sealed for a year on some woods and 2 or more for others. Eventually the wax starts peeling and that may be why those start to check.
We all live in different areas and store our wood differently. I think each place has to solve it's own problems. I still lose wood stored outside but have slowed it down many fold over what used to happen. That's it middle Tennessee. Your mileage may vary, a lot.
Katherine Kowalski
I've had some Anchorseal stored in regular plastic milk jugs stored for over a year... and no leaks or cracks. Could be my environment... (Dry dry dry, no heat or a/c in the shop). ??? As you said, mileage may vary.
Katherine
Katherine it was wet, and often temperature extremes in my former shop. I had it happen twice before I realized it was the container. I thought maybe I was being to rough with the jug or something. Hasn't happened since but I started using old photo chemistry jugs that I unfortunately can't get any more since we went digital and closed the darkroom.
Milk Jugs....
are polyethylene. Very subject to UV degradation. A few hours or days of sunlight will ruin Poly. I am not a chemist, but some of it may be stabilized to resist UV, but I doubt they bother with it in milk jugs. John, did sunlight reach your jugs?
Re: Milk Jugs....
Barry I tried that pick up line in a bar once. Doesn't work.
No sunlight didn't ever hit my jugs, they were in the basement.
Folgers Coffe containers,
Jorge Casta�eda
Work very well, they are red plastic so UV is not a problem, I have one in one of my work spaces for 4 years, the 10.8 ounces jar and a second one to store a brush to apply it with.
In my other work area, I have a substantial polyethylene 1 quart "bucket" with a lid, sold for paint and such at the hardware store, after 2 years it is in fine shape, when I have to go on a field trip I take this one and the brush lives in a freezer bag.
Maxwell House
Doc Green
I've been sopping a bit of anchorseal lately and just happen to have a photo of my container.
I only put about a half inch (depth) into the jug at one time. The brush lives inside the container. Just snap on the lid when you're done, without any cleanup, and it will keep for months without drying out.
I've been using this one for a couple of years now, and it seems to be good as new. ~Doc
great idea- thanks for posting!
steven antonucci
I'm not a coffe drinker
Doc that's a great idea. I'll have to steal one from work. I use the same method sort of. I have a smaller closeable container and just lay the brush on top when I'm done. Letting the brush sit in the anchorseal for a minute or so before use softens it right back up. I like being able to keep it all in the container.
Re: Maxwell House
Carole Valentine
I've been using a Maxwell House container for years for my Anchorseal, Doc. I have a tight slot cut in the lid and the brush just stays in the lid, even when I am using it. I think the container I am currently using has been on duty for about 5 years. I used to save the containers thinking I would always have a replacement when needed, but eventually started throwing them out since they seem to be indestructible. When all else in the landfills is gone, I suspect those coffee containers will still look brand new! (not a good thing, so they go into a recycling bag now)
Re: Maxwell House
Dale Miner
Doc,
Same method here, only mine is a Folgers coffee 'can' from Costco and is a little bit taller. The built in handle make moving the container around with anchorsealed hands a no problem matter.
