Jet mini Lethality ?
Doc Green
Mike R's "wondering" about the Jet mini got me to thinking about it, and I did a bit of scribbling to see what the numbers looked like.
My Jet 10-14 has a 1/2 HP motor. I assumed it to be turning at 2,000 RPM and turning a spindle, or whatever, that is 2.5" in diameter. Then, something gets wrapped around the spindle.
The pull exerted on whatever is wrapping up would be about 12 pounds.
It would wind up a one-foot length in about 46 milliseconds, which is on the order of 1/10 the time it takes a human to react. The implication is that you could be all wrapped up in the thing before you could even flex a muscle, or say "OH S--- !"
Now, the motor may not develop a full 1/2 HP at 2,000 RPM so the pull of 12 lbs may be overstated. However, you must also take into account the stored energy in the rotating spindle, chuck, motor armature, etc., if the whole thing is to be brought to a sudden stop. This force would be far greater than the 12 lbs the motor can exert while running without slowing down.
This is FWIW. The accident involving the young lady is very sad; a tragedy.
~Doc
