Dust removal from Baldor Grinder......
Jesper, Denmark
Jesper, Denmark
Some time ago, I asked for ideas for removing the dust from a grinder. the consensus turned out to be using an inexpensive vacuum cleaner. here is the set-up:
The dust is collected in a simple plywood chamber, with appropriate holes connecting to the grinder. The chamber just sits there and no special attention has been paid to sealing or fastening.
The vacuum cleaner is an El-Cheapo, selected for it's stainless steel tub and price of around $50.
Holes have been cut through the box for passing of the square tubing of the OneWay grinding Jig.
So far it seems to be very effective. The next little modification is to wire both the grinder and the vacuum cleaner to the same switch, so they both start at the same time. As the vacuum is a little noisy, I will probably build some kind of sound enclosure around it.
Re: Dust removal from Baldor Grinder......
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Looks like a great solution Jesper,
I was thinking after seeing your solution about a NYW router table I built some time ago. In the collection chamber there was a baffle built to assist in the collection of wood shavings, I am sure your box design will work well, but if you wanted to add some "pull" to the box perhaps a baffle might be an additional thought.
You can see the adjustable plate in this image
Take care,
Jim
Jesper, Denmark
Jesper, Denmark
Thanks Jim,
I built the Norm Router table several years ago, and it has a similar baffle, but not adjustable. The dust collection from that is excellent. It has a plexiglass door in front with vent holes in the bottom.
The vacuum cleaner for the grinder seems to have plenty of suction and air flow, so very little grinding dust escapes.
The next move is to arrange dust/chip extraction from the whole shop. I have a 4 kW blower with filter installed in the attick, so now it is "only" a matter of piping and where to fit a cyclone.
There is a drawback in having a direct connection between the house and shop - it seems that Ii am chasing dustbunnies forever in the house. Natural convection draws air from the shop into the house, so I have to do something about that.
Re: Dust removal  ? Warning
Terry Scott
Jesper I maybe barking up the wrong tree
I would be a bit concerned that the dust may com-bust and a fire start ,Or the filter in the vac catch fire
Yes the sparks are minimal
But I have ground some metals and the sparks have joined into a hot lump burning a hole in my work bench.Also once a smoldering started in the accumulated dust from sanding that had settled on the bench (your workshop does look cleaner than mine )Maybe some sort of baffle in the wooden catchment area ?
I welcome the experts to correct me if Iam wrong
Good Idea, Jasper
Remember, though, that the AlO dust that is the worst is the really fine stuff so make sure you've got a good filter on that vac. I haven't done mine because I moved the turning stuff (and grinders) to the garage so I've got lots of natural ventilation when the grinder's running.
Jesper, Denmark
Jesper, Denmark
It's a very valid point. The main purpose apart from not having the mess - was to separate the grinding dust from combustible dust from wood.
since the wooden box is not nailed down, but just sits there, it will be checked occasionally to look for traces of trouble. The vac is wet/dry, so has a couple of inches of wwater in the bottom - don't know how long it will stay there, but I will look frequently for a while.
my experience from just having the crap discharge behind the grinder has been that the sparks from the grinding never emerged from the discharge outlets.
So, the concern is definitely there and will be watched. I may line the wooden box with sheet metal at some pont, but for now it is just careful watching.
Tthe dust itself is not combustible, and I really doubt that there is enough energy in the sparks to set the wood on fire.
Re: Warning
Jasper,
If you leave that water sitting in the vac, you will wind up with a bacteria and mold farm. Dust from the air with get in bringing all the germs with it.
If you're going to reply on the water for fire control, you'll need to change it and rinse the tank each week.
