Death at Wood Lathe really Sad.
Re: Death at Wood Lathe really Sad.
Barb Siddiqui
Barb Siddiqui
I had read a student died in a Chemistry Lab, but had no idea she was in a machine shop. This is incredibly bad. Her instructor must be inconsolable.
Yuck.
Dave Belser
That's terrible, and to think it could have been avoided by basic safety precautions - Never work with loose clothing or hair that isn't tied up and tucked in.
My High School shop had a picture near the lathe of someones hair and scalp wrapped around a spindle. Quite gruesome and it sure got the point across.
Jorge Casta�eda
What a tragedy, let's keep safety above all in our minds.
Rest in peace Michelle...
Mike Rubes, Apex, NC
Wow, that is awful.
I wonder what lathe she was working on? I've thought about this before and I really don't think my Jet Mini is strong enough to kill me, but I could be wrong. Now, a PM 3520 or something could easily do it, but it is so easy to stall the mini, I wonder if there is enough power to choke someone?
Safety first, that is such an avoidable accident.
M
Treating all the tools with respect in Apex, NC
Barry
We normally think of a wood lathe as a very safe machine.......and it is when proper safety precautions are observed. But, when they are not, it can become deadly.
Mike Stafford
Mike Stafford
Many years ago while I was in college I worked third shift as a machinist at a large turbine components facility. I operated a variety of machines most were controlled by tape drives and the operator only had to know how to measure the parts and compensate for tool wear and replace the cutter when it became too dull to use.
A few workstations away from me was a young guy with hair down to his waist which he usually kept tucked under his bump cap. On this particular evening he was installing and checking a new cutterhead on a horizontal milling machine. He leaned over to see where the cutter was going to make contact while he was jogging the table under the cutter. His hair fell out from under his bump cap and became entangled in the table. Somehow he hit fast jog and the table lurched toward the spinning cutterhead.
No, his head did not make contact with the cutter. There was not enough room but the table continued to move with his hair entangled. The majority of his scalp was pulled off by the machine. I will never forget the screams or the sight of this horrible accident.
Flex Shafts & Dremel Tools Too
charlie belden
Taught jewelry making for a dozen years in a fully outfitted shop - each student having a flex shaft at their bench. When I was a student I saw several people get their hair wrapped around a spinning tool. Some merely lost some hair. Others ran a nice sharp, spinning at high rpms, - up their forehead AND lost some hair.
Despite spending 15 to 20 minutes going over what a flex shaft driven cutting instrument COULD do to you, every year or two someone would FORGET, get in close to see exactly where the bur was cutting - and that spinning sucker would wind itself up their forehead and stick itself to their scalp. Fortunately, we also used scalpels for carving wax, so severing bound up hair - in very tight quarters freed them from the flex shaft.
Sharp burs in flex shafts or dremels also could run out of a cut - and into fingers on the run out side of the work. They remove skin faster than they remove wood. Unlike on wood, blood is very easy to get off metal.
Spinning things CAN grab things.
Being BALD around spinning things has its advantages.
I turn with a Dead Man foot switch - just in case. Limits my range of motion a bit - but the time lost adapting to that is much less than my Healing Time.
From this tragedy - perhaps a higher state of awareness.
Let's be careful out there.
David Walser
...I've thought about this before and I really don't think my Jet Mini is strong enough to kill me, but I could be wrong....
You are wrong. If you were wearing a cord around your neck (or long hair) and if that cord were to get caught by the spindle, your tiny Jet would have more than enough power to cut off your air and blood flow. Granted, you most likely you could escape by turning off the lathe (or pulling the plug if you couldn't reach the switch). But, what if the tangle was such that turning off the machine didn't release the tension on the cord? You could easily pass-out (and then die) before you could disentangle the cord from the spindle.
I'm not trying to be morbid nor fanciful. I'm just pointing out that any lathe that is large enough to do "real work" is also large enough to kill. All of our lathes need to be respected for what they are -- potentially very dangerous machines.
Maybe not a wood lathe....
Rob Wwallace
Apparently there are mixed reports as to whether the lathe being used was a wood lathe or a metal lathe.
She was an astronomy major, and likely was working on a piece of equipment on a metal lathe. This is what some of the news reports are saying. She died of asphyxiation by being pulled into the machine and apparently unable to breathe due to neck compression.
Regardless, it is a grim reminder that even the most basic safety rules need to be heeded, regardless of the turner's skill level. A sad and completely avoidable accident.
Rob Wallace
Really sad is right
Mike Foster
But totally preventable. I did a google search on the incident and found out a little more information. Michele (a senior due to graduate in 2 wks) helped write the lab shop safety rules for under grads and was in an advanced course on machine shop protocols. From what I read, she was diligent in safety protocols, and I would guess she thought something like "I'm ok for this little procedure". Truly a tragedy for those who loved her.
My son is in art school and has taken various courses in woodworking and metal working. Students are not allowed to work in the shops unsupervised, which I am grateful for. I am guessing Yale will be revisiting their policy of letting students use such equipment unsupervised (she was in the shop at night, alone).
Keith Tompkins
keith tompkins
Barry, most machinery will hurt you, sometimes severerly. But, the lathe is one that will certainly kill you. From entanglement to flying hunks of wood, one must use caution. I had a (newbie) student wearing a long-sleeve sweater who got very annoyed when I asked them to remove it. They had no idea what could have happened if they got caught up in the machine.
Another bad day, on another tool. *LINK*
Keith Newton----Little Rock, Arkansas
Sometimes it is the little thing that get you.
Here is a link to another accident that showed up this morning.
Don't look at the images if you are squeamish, or have just eaten. This guy really got mangled.
http://www.woodweb.com/cgi-bin/forums/dust.pl?read=684684
Re: Another Wood Lathe Accident
Barry
So true. In another lifetime, when I was doing student teaching in Industrial Education, I witnessed an accident. One of the students was on a wood lathe turning the obligatory 1 1/2" X 6" cylinder.....and running his cupped hand along the top of the cylinder to assess what a good job he was doing. The instructor saw what he was doing and before he could speak, it happened. The spinning cylinder caught the flesh of the palm of his hand between the tool rest and ripped a goodly portion loose. Blood was everywhere and the kid almost passed out. It took a trip to the ER and a few dozen stitches to put things right. But a lesson was learned.........by the entire class.
Richard Allen
Richard Allen
Very sad.
Brad Vietje
Brad Vietje
This is another great reason to use a dead cup center as a drive center and stop using the 4-pronged thing that comes with all lathes. We could re-name it the "Safety Center", and make them standard issue again.
Safe spinning,
Brad Vietje
Newbury, VT
Another
Ralph Lindberg
What was it 2009? When the turner in Canada was killed when the bowl he was turning flew apart.
It was just last week when my wife's hair got caught in the chuck on our Mini. Fortunately she only lost a few strands
This does sound like a metal lathe but i did see..
Doug Thompson near Cleveland
I did see a girl that caught her long hair in a mini lathe, the hair was wrapped around the spindle. When she untangled the mess her forehead had a little blood but other than that she was more embarassed than anything.
You can get hurt if your clothes/hair get caught in any spindle but I think the greatest danger is from high RPM's that is the trend right now... it's just a matter of time...
I am very sorry to read about this accident, God bless her.
Rob Wallace
Re: This does sound like a metal lathe but i did s
Rob Wallace
Doug:
Several on-line articles I read imply that it was a metalworking lathe she was using to work on a physics/astronomy project.
For example:
http://www.allmetronews.com/news/65239-yale-student-michele-dufault-dies-in-chemistry-lab-accident.html
Most of the dozen or more articles I read seem to repeat the same general vague information, but it does not seem very likely to me that she was turning wood for a physics/astronomy project when this happened.
I am including a link this tragedy in our Chapter's e-newsletter in case others may have missed it on this and several other forums. All turners must learn from these unfortunate incidences.
Rob Wallace
You are so right Doug!
Stephen Mushinski
So sad! I feel for this young girls family. This type of accident happens so fast - in the blink of an eye!
Doug I couldn't agree more.
We all know the demonstrators that are turning platters at 3000 rpm. Yes you get a wonderful finish off the tool and so forth. Do I think they turn safe - well yes as they know what they are doing, check the wood they are using, stay out of the line of fire.
Is it safe for the average hobbyist woodturner that is the target audience is.
NO NO NO and Never!
Show casing this encourages it!
We have had these demo's at our club and I just shake my head and hope one of members is not one of the unlucky people that makes that little mistake that takes their life!
Re: Another
Stephen Mushinski
Yes it was in Canada two years ago.
My understand was the turner was hit in the head by a chuck of wood coming off the lathe. Also a broken roughing gouge was also found. If my memory serves be right.
It was in Ontario.
Steven Antonucci
Makes me wonder
steven antonucci
What was her mistake? Was she caught by her hair, or a long sleeve or loose clothing? It suggests that she was choked out, but if it was her hair, I can understand how it would have wrapped around her own throat?
It does sound like an older lathe to me. Probably one of those old school cast iron beasts. They have enough power to cause some serious damage.
My heart goes out to the family.
S
Wow
Barbara Gill
During the 22 years I was in the rescue squad I saw some amazing things but that tops them all!
I assume the glue spreader was for plywood?
Personal Experience....
first, let me say I am very sad for her and her family and I grieve for them.
I wear a face shield, especially when roughing. I had lightning hit a tree in my yard and salvaged a piece of wood from it. About 14" long and 7 in diameter. Normally I put the shield on with my right hand and turn the lathe on with my left. Somehow, the left hand got there first and the piece of wood flew off the lathe and hit me right between the eyes. My glasses flew away as my head snapped back. Bleeding like the proverbial stuck pig. Slapped a fist full of paper towels on it. Couldn't see to drive. Called a neighbor for help. 27 stitches later I was home with a new eyebrow. I am still not sure why the wood launched itself. I had spun it by hand and it cleared the rest. I think the lathe was set way too fast, but I don't know. I have no doubt a lathe could kill you. and i don't know why anyone thinks of it as a safe machine.
Truly unfortunate-and scary.
Don Orr
My sympathies to her family. A good one gone too soon. Who knows how she might have changed the world.
