Inlay Question
Inlay Question
Inlay Question
Dick Wilson
In one of Jimmy Clewes's videos he uses gold powder as an inlay. Have any of you used this powder???? I bought the powder and tried it, and was not happy with the results. When I turned off the excess it wasn't really gold looking. I think he mixed the powder with epoxy. What's the secret??????? thanks
I have used key shavings but was not happy with that either because along with the brass there are billions of grinding wheel speck in it which really dulls the brass finish.
Re: Inlay Question
Re: Inlay Question
I find when using ground up metal that you need a lot of it so there aren't many gaps for the epoxy to fill. Either that or very large chunks of epoxy. You also have to sand the metal inlay to a much higher grit, at least 600, higher is better. I have used a silver powder but it was extremely fine. It was hard to mix and still doesn't look like silver, more like silver colored pressed wood.
Re: Inlay Question
Don Leydens
Re: Inlay Question
Don Leydens
Hi Dick! I have the same video and tried the same thing with the same disappointing results. My inlay looked like a dull band of solid copper.
I believe it was the size of the particles I was using. I found a supplier that had much larger particles and the inlay looked great. Nice and gold and sparkly. Unfortunately, I used it all and don't remember where I purchased it. Anyway, maybe larger particles will give you the look you're after.
Hope this helps.
Re: Inlay Question
Re: Inlay Question
Wally Dickerman in Arizona
Go to Michaels and get some gold and some red Sparkle or Glitter. Add some of the gold and a small amount of the red. Helps a lot to get some sparkle in the mix.
When I use turquoise I add some blue sparkle and a little red to the mix. I like the results.
