Re: Stain
Rob Wwallace
Hi Dave:
Depends if it is a dye or a stain.
If it is a dye-based "stain" (a true dye), you'll have to try to change the dye chemically with a bleaching compound (such as a chlorine bleach [i.e. Chlorox]) or an oxidizer like Oxy-clean, and if this doesn't work, you'll have to live with stained skin for a while, or attempt to wash it away be re-dissolving it in a solvent. Not easy, but possible.
If it is a particle-based stain, you will have to try to re-suspend the stain particles from the nooks and crannies of your skin with an appropriate and hopefully safe solvent. Suggestions that have been made to use mineral spirits or an alcohol (like denatured alcohol) may work to remove some of the stain particles, and reduce the intensity of the stain. Believe it or not, I have had success spraying the stained skin with WD-40, and then rubbing away a lot of stain with dry cotton cloths (used T-shirts or old socks that get one more life in the shop for cleaning before getting trashed). I then immediately wash the skin repeatedly with warm water and lots of soap to assist in suspending the particles and washing them away. Most of the time this works well for me.
If working with organic solvents, remember that some like lacquer thinner, acetone, xylene, and several others can be easily absorbed into the body transdermally, and should be avoided. Check the labels on the containers, or look up an MSDS on the web before using any solvent as a skin cleaner.
Rob Wallace
