200+ woodworking book reviews
Spinning wheel
Spinning wheel
Jim Barbour
Spinning wheel
Jim Barbour
My young son has suggested I make a spinning wheel for him to give his wife for Christmas. I'm intrigued by the notion. Does anyone have suggestions on where to get the miscellaneous hardware needed? Have you made a spinning wheel? Any advice?
I have looked at various plans but am not settled on anything yet. Thanks in advance for your input.
Re: Spinning wheel
Richard Allen
Re: Spinning wheel
Richard Allen
Look for ISBN 0936984058
This is the "A No-Lathe Saxony-Style Spinning Wheel Construction Manual"
by Richard Schneider
While this is a no-lathe book you can easily trade many of the non-turned components with turned spindles.
Anyway the book is cheap enough and covers the topic of constructing a spinning wheel with enough detail that your project will almost certainly be successful.
Re: Spinning wheel
Ken Vaughan
Spinning wheels and Spinners
Ken Vaughan
Jim -- I live with a spinner/weaver and there are some techinical things that need to be worked out with the spinner early in the process or you will likely create a floor decoration. I have not made any from scratch, but have rebuilt and modified several for the Spinner. The Spinner likes fine yarn with long stable wool, and has recently moved to cotton. Electric power is popular and the head may be moved to platform and powered by motor instead of pedals. If pedals, think double pedal for sure.
The spinning is all about the head -- that is where the fiber is spun and stored. The kind of fiber and yarn-thread being produced makes a big difference in the speeds and methods of drive/tension system used. If the head does not do what is desired, you have a floor ornament. Most of those old spinning wheels and many of the middle aged ones are good for knitting worsted yards, and lack the ability to vary the yarn size and twist to handle the more contemporary finer yarns well. Talk to the knitter, and consider purchase of a head if you do not want to get into the really serious part of the spining.
Everything else in the spinning wheel system is either a platform to hold things, or a power system to operate the head.
I have modified some of the Spinners wheels to include modern bearings and added double treadles. You may need to take some photos of working double treadle wheels, and practice with a MAPP torch and drill rod, but it is not highly complex.
Take a hard look at Castle (vertical) designs, so if it becomes a floor decoration, it takes up the least square feet possible, and allows lots of spindle turning.
I have an out of print book hiding here on restorations -- or contact me if I can be of help.
Re: Spinning wheel
and another:
Jorge Casta�eda
This plans I found somewhere long time ago... sorry i forgot the source:
Looks simpler than the one above.
