sharpening tips video *LINK*
Here is another video I did to try and explain how I sharpen my thompson detail gouge. I thought I would include sharpening the bowl gouge because that leads directly to how I sharpen the detail gouge. I also thought it would be handy for newbie's to show how to grind a more traditional bowl gouge grind using a tool rest. I used the Stewart Batty grind because I think it's easy to learn and is a good shape for a gouge.
I'm still learning to edit but most of the problem is shooting the video myself while being the main character. It's fun learning. I hope to make more of these "shorts". Maybe it will help someone.
http://www.youtube.com/watch?v=Xbggxj2kgyc
Re: sharpening tips video *LINK*
Carol Reed, Strawberry, AZ
Another good one, John. Gave me an idea or two for my set up which is a 1" belt sander with the Lee Valley blue Zirconium belts and the leather honing belt on a very slow motor. I do have a high speed grinder for shaping tools, but I use the strip sander for sharpening them.
Ian Jeffcock
John, that's a well made video. Thanks for sharing.
George Guadiane
The little riser block is a brilliant adaptation that I'm going to add to my sharpening setup. Overall, the video is great!
BTW, tell us about your camera and sound. What are you using?
The camera is a Canon ZR900. When I went looking I had 2 main objectives. It had to have manual focus options and had to have a remote mike. It also had to focus close enough to see good detail.
The manual focus is a pain to use but it does work. Auto focus sucks in woodturning. I run cameras at a lot of turning demos and I'm constantly frustrated at their lack of focusing where you want. The downside of manual focus is that since I'm also the one doing the demo I can't just move the tools around anywhere. It would be great to have someone to focus the camera where ever I move a tool. I'm working on the editing thing this week so that I can stop, move the camera, zoom in on the tool and do a close up to better explain the detail. Then I'll just edit this in instead of trying to do it all in one take.
If you noticed in this video the sound fades in and out and the grinder was kind of noisy. That's because my remote mike broke. That sucks, I only used the thing a dozen times or fewer. The remote mike gives much clearer sound and also reduces the lathe and grinder noise.
I really wanted a digital camera instead of using tape. However price was a factor and the cheapest digital with manual focus and remote mike was over $600. I think this one ran about $300 or less. The only real downside is it takes the full time you shot the video to download it. Digital cameras will download very fast. Many digital cameras will also dump straight to youtube. Of course you can't edit it when you do that.
I'm currrently in the market for some editing software. I'm using Imovie at work and that's all that I have right now. Of course it's a pain to have to stay after or come in on a sunday to download and work on a movie. It works pretty well but I just can't justify buying a mac for home. They are twice as expensive as the PC my son is building for me a he will build in more useful options so I'd rather not go the Mac route if I can find another way.
Re:Great Job.  Keep them coming!
matt overton
I liked the view of just your mouth. Very professional video, and great explanations and delivery.
Re: quick question
Steve Criscenzo
John
Great video. Keep them comming.
I have one question. You show a fixed setting for your vari grind. How do you account for different angles on your gorges particularly bowl vs spindle.
Steve
Bill Neddow
This is a very good video, John. The riser block is a great idea. I will have to make one. I also looked at your video on the No.4 Hunter tool and just got off the phone from ordering one.
Re: quick question
Steve That's the reason for the little block I showed in the video. It raises the gouge. I'm using the exact same setting for the bowl gouge and spindle gouge. the bowl gouge is 50 degree front bevel and with the block installed the spindle gouge comes out at 35 degrees. You could do exactly the same thing by moving the V arm closer. that means you have to adjust the V arm each time you switch from bowl to spindle gouge.
I have spindle gouges ground from 35 up to about 50 depending on the use and shape. If I use the Wolverine jig to sharpen those I leave it exactly the same. I never move the adjustable arm. I simply change where the V arm of the Oneway jig sits in relation to the wheel.
I didn't show it in the video but some spindle gouges I push up the stone when cutting the outer edges of the grind. It just depends on the gouge and flute shape of the gouge.
Love my #4 and #5 hunter
I used the #4 several times this weekend to solve a problem piece.
Don Leydens
Don Leydens
Thanks for the video, John. That riser block is a great idea!
Thanks, John.
I have some ideas....
Aage Rendalen
Thanks for taking the time
Aage Rendalen
John, I'm not the only appreciating your taking the time to make these instructional videos. Thank you.
Phil Powell
John,
Good work! That little chunk of wood in the "V" is a great idea. I've already
stolen it. You must have more ideas to share. Thanks!
Jerry Hall
John, Beautifully presented. Slick idea to avoid resetting the arm any more than needed. Especially like the simplicity of the Batty grind technique. Will have to give it a try. Is this a grind that you use regularly? Pros and Cons? Jerry
I'm using the Batty grind more and more. I'm still learning with it. Stewart claims that the 45 degree angle produces the least pressure in the bevel and that coupled with the 45 degree cutting edge gives a cleaner cut. Sometimes it does and sometimes it doesn't. It's probably me. So far I can get the cleanest cuts with the Hunter tool but it's a little hard to control the shape of the cut. The Batty grind lets me control the shape better but since it's a shallow grind I can't use it for many of the bowls I turn. It's an interesting tool and cuts very clean.
Bill Blasic
Bill Blasic
John,
Have you given any thought to dubbing the sound over the video after recording? You could concentrate on the video and put in the voice later.
Bill
Bill I have. I also plan to learn to add still photos of drawings. I would love to be able to add colored lines and arrows to show the bevel direction or maybe direction of the grain of the wood. I know that can be done in photo shop but don't have any idea how to do it movies. I have a long way to go learn what is possible in video. John
Bill Blasic
Bill Blasic
John,
I recently purchased Movie Edit Pro 17 HD. I haven't done much yet other than to make and burn one Blueray movie. It's a lot of program for $60 and will output to You Tube among others. Manual or Automatic Audio dubbing is just one feature. I had planned to do some video work this past winter but just could not find the time. I' happy with the program for the little I've done with it. Probably just one program of many that are easy to use. Keep up the videos and your instruction as they are always useful.
Bill
Steve Kubien
Steve Kubien
Very nicely done John. Too many folks make sharpening this long drawn out ordeal and totally over-analyze the process. You've made all of this look really simple, the way it should be.
One question... The gouge you have the Batty grind on... U or V shaped flute? Can I put this grind on a P&N bowl gouge (might be a supagouge, can't remember) with totally mucking it up?
Steve I will have to look. It is an older Henry Taylor bowl gouge and I think it's either a U shape or modified U but will have to look at it tonight to tell you.
Scott in Falcon
Hi John,
Would you mind elaborating a little more on how you made your gauges for setting the v-arm distance? You mentioned setting them alongside the wheel, marking the curve and then taking out some of the extra in the center. My question is how do you determine the size of the gauge and the distance of the arm initially to determine the grind angle you want for the tool?
Thanks,
Scott
HeatherAinAK
I took a class with Stewart and he showed us how to do the v shape bowl gouges. He actually does his sharpening backward from what John shows. He starts with the flute up and to the the left when you are sharpening the left side of the flute. With the v shape flute he had us stay move the tool straight left and right for a few nanoseconds before sweeping around the front and then doing the same thing on the right side. He described it as sharpening like a skew, then sweeping aroung like a spindle gouge, then another skew on the other side. This is opposed to the u shape flute which is a more fluid sweep from one side to another.
I had a hard time with how far over to turn the flute. He had me put a little tag of tape inside the flute of the tool like a flag. When the tool is turned over to do the sides, this flag should be parallel to the tool rest whick was placed at 40 degrees from the wheel (anywhere between 40 - 44 is fine but never over 45). This is what makes the consistent bevel angle all the way around the tool, which is what John described.
Hope that helps,
Heather
Scott You have to establish the grind first. Oneway has suggestions that come with the Wolverine, Doug Thompson has a description of how he sharpens using the jig on his website. Or you can feel free to come up with your own grind.
Where the V arm goes is based on the angle you want at the tip. If your gouge already has the correct angle then you just put it in the Wolverine jig and adjust the V arm until the bevel is flat on the grinding wheel. this is the position you want the V arm to make the wooden jig. Hope that makes sense.
