Another new Sierra Pen
Andy Lincoln,in Dearborn MI
Hi All,
Sometime last week a post was made on IAP asking about metal segmented pens.The pen used in the post was inspiring to me so today I attempted a pen in a similar style.The woods used are maple and (I think) padauk.I joined the wood to some thin aluminum with 2 part epoxy.I then drilled the entire blank at one time and epoxied in the tube.
I turned the blank to near final size and then drilled and applied solder to make the dots in the padauk band.I had a hard time getting the solder to bond with the wood and had it catch a couple times when using tools.My solution was to use CA glue to help adhere the solder to the wood and after sufficient drying time I was then able to sand the blank/dots into final shape.Once again it was all a learning experience
The finish is CA/BLO on a Sierra kit plated with chrome and gunmetal.I am happy with the look of the pen After assembling I wished that I had turned the center area slightly smaller,but holding it it feels pretty good so I am done fretting over that .This latest batch of penkits are from a supplier in Australia at
Timberbits The plating is upscale and the ink refill is a Schmidt P900 which is significantly nicer than then the refills/ink in the lower priced kits.I am beginning to understand the get what you pay for motto. I am also ,slowly ,gaining confidence in my abilities and feel like I can work with the more expensive kits.Not ready for the real high end stuff yet,so Shaver you still have no worries or competiton
Thanks for looking,
Andy
