A55 Smoothing Plane
Waterlox
Waterlox
Waterlox
Bruce Smith
I wonder how many of you turners have used Waterlox (satin) on some of your bowls?
I started using it about a month ago on some of my bowls and what a nice job it does,
However, storing the partly filled can for future use in another story. I found that a scum
formed over night on the surface and the product below the scum was gelled with lumps
in it and consistency was thick, it reminded me of think tapioca puding execpt that it was
brown instead of white. I have tried using Bloxygen and or Propane before placing the lid
on the tin with no success. Yesterday I strained the product through a piece of old nylon
stocking (panty hose) and, did it ever go through slow and what did go through was still
jelly consisteny. Its too late now but I think I shall try one more tin and use marbles to
displace the air. Has anyone experienced this problem? Thanks in advance.
Re: Waterlox
Re: Waterlox
Carole Valentine
An age old discussion! :D I use Waterlox almost exclusively. I pour out just what I will use, immediately squirt Bloxygen in the can and replace BOTH lids tightly. Never dip a brush or cloth into an open can or pour unused finish back in the can! The can I am using right now has been open for about a year I think and is fine. It is about a third full. BTW...I use Waterlox Original. Would make me nervous to use propane!
Re: Waterlox
Dick Hines
Re: Waterlox
Dick Hines
Get some small jars, baby food jars work great. Put your Waterlox in the jars, cover the jars with kitchen wrap. Put the lid on tight and store the jars UPSIDE DOWN. You will still get a film but it will bo on the bottom.
Any small jelly jars will work as long as they have good seals. If you know someone who is feeding a little critter there will be enough jars for a life time. And they will be glad to get rid of the jars.
PS. they are great for storeing hooks for you fly tying people.
Re: Waterlox
Re: Waterlox
Ed Heuslein
Bruce, here are a couple remedies that really do work.
1. The easiest. Get a wood hand clamp (the kind with two handles) and just squeeze the can 'till the liquid is at the top then put the cap on. I have a friend who does this and he never has a problem.
2. What I do is find someone who drinks wine from one of those cardboard boxes with a plastic bladder (you won't find many who will admit to this - especially here in the South). Remove the spout (it pulls right off). Wash the bag and let it dry. Then put the Waterlox in it. Squeeze ALL the air out of it 'till the liquid is at the top. Replace the spout. Put it back in the box. As you use it, no air can get back into the bag and the Waterlox stays like new. I have a box in the shop right now that is almost three years old. It only has about a half cup left but it's as good as new.
Try it. You'll like it.
Re: Waterlox
Re: Waterlox
woodspinner-Harry robinette
I've been using Waterlox original Gloss for about a month on some flat work I've been doing and haven't
had any problems at all ,I just went to the shop and looked and it's still just fine.Don't know way yours is doing that or way mine isn't. Very strange.This is the first time I've used Waterlox sorry I can't help.
Re: Waterlox
Re: Waterlox
Bernie Weishapl
I buy the smallest can I can get in the original. I do like Carol and pour out what I think I will need the spray Bloxygen into the can replacing the lid. It is about 8 months old and still very liquid.
Re: Waterlox
Re: Waterlox
Emmett Manley, Lakeland, TN
I love the Waterlox finish on certain woods, but I hate the constant problem with gelling and clumping.
I assume the problem develops because the mineral spirit component has evaporated to a percentage that will not keep the oils in solution, but I have not been successful in dissolving the clumps by adding mineral spirits.
The suggestions for preventing gelling are interesting and seem to work, so I will give the less involved procedures a try -- probably not the wine bladder or the can crushing.
Does anyone use a tung oil based product similar to Waterlox that does NOT gel? Or, should I just try pure tung oil?
Re: Waterlox
Re: Waterlox
I did some more research and now realize the Waterlox gelling is an oxidation process, not a solubility problem. I'll purchase some inert gas product, as Bloxygen.
