Abalone Shell
Abalone Shell
Abalone Shell
Tom Vensel
I have used abalone shell and mother of pearl in the past for inlays in banjo necks . I would now like to take a section of an abalone shell and crush it and use it as crack filler in a maple bowl that I have turned . In the past I have always used sawdust or coffee grounds and wood glue or epoxy . Has anyone out there ever used ground abalone as a filler ? What glue would be best ? Woodglue, epoxy,superglue ?? I do know that abalone dust is pretty toxic to work with .
Thanks in advance
Tom Vensel in S/E Ohio
Re: Abalone Shell
Why do it?
Once you grind up the abalone shell, it won't have any of the visual properties of abalone anymore. Might as well use gray plaster and not worry about inhaling the dust.
Re: Abalone Shell
Re: Why do it?
Bill Turpin in WNC mountains
Right, Ellis
The abalone visual effect comes from light reflecting and passing thru multiple layers of shell. Crushed, there are no multiple layers.
Re: Abalone Shell
Ken Vaughan
Crushed Abalone Shell
Ken Vaughan
When you get it crushed you will have a power that is white to grey with an occasional piece of nacre surface (the nacre is the part that looks neat). If your are crushing abalone veneer, you might see a few more pieces
You might think of black resin partial fill with pieces of shell set on that then topped with clear resin (mosiac). The polished clear resin will show the abalone well.
Crushed, expect a light toned muddy emulsion in clear resin.
Re: Abalone Shell
Re: Abalone Shell
Galen Vetterick
Craft stores have ultra fine irridescent and crystal glitters. Not sure how well they would reflect in epoxy. Probably what is in some pen blanks to get the irridescent look though.
Re: Abalone Shell
Re: Crushed Abalone Shell
Tom Vensel
Thanks for the info . Sounds like I would not get the look I was wanting .I might buy some Inlace or go back to coffee grounds and epoxy . Tom Vensel
Re: Abalone Shell
Doug Trembath
Tom, keep in mind that we all think of "Crushed" in very different terms, it seems. I have used "crushed" Turquoise many times to fill voids in turnings. My idea of crushed was to put the rough pieces into a sock or rolled up canvas and beat it lightly with a hammer, until the pieces were reduced to the size I wanted. The key here is the size. If you run it through a coffee grinder, or something, you obviously would lose the irridescence of the Abalone, but if it's just broken to the level of 1/16" or so pieces, I would think the visual would survive. Can't hurt to experiment on a separate piece. I've seen Abalone done this way in jewelry, much like the crushed Turquoise jewelry.
Like I said, it can't hurt to try!
Doug Trembath
Re: Abalone Shell
Tom Vensel
Hi Doug, What you described is actully what I was talking about . I should have not used the word "crushed". I think I will expirement with it . I'll try to break it into tiny pieces and screen out any dust . Thanks , Tom Vensel
Re: Abalone Shell
Ken Vaughan
Abalone Shell Mosiac
Ken Vaughan
Abalone in pieces does make very nice mosiac -- I like it with a black background. If you are using the raw shell -- it is ugly to cut or grind the waste away. Veneer leaves that step to those with better gear and eyes than mine. There is a good side and not good side -
the critters grow in the waters around here and I have tried the cut and grind drill -- suggest it be avoided if possible. they do eat good though.
