Now if I only had a large converter....
3 hp, 3 phase. 72" bed, 12" swing.
Oliver lathe in High Point, NC.
If I bid on this one, I know the LOML would have some serious words with me.
Re: Now if I only had a large converter....
Neat dust collector.
Adrien
Ken Romines
I usually don't believe in goading people into doing something when they are hesitant, however, get it! I have looked at this machine (I think) on an auction site and I really, really want it. I have a Delta lathe that I put a 3 phase motor on (because I had it)and a varialble speed control that works like a dream. So, talk or bribe your wife into it, it will probably be pretty reasonable. I just glad I live in Texas and the machine is in your part of the world or we would be bidding against each other. And I don't have to explain to my wife why I want another lathe.
Ken
Doug Trembath
Many years ago, I bought one much like it, but the motor housing had been run into with a forklift, and the motor was junk. Got it really cheap. I only used the legs, bed, and tailstock, and junked the original motor.
I built a headstock to allow 24" throw, built a riser for the tailstock, and a banjo along with various toolrests.
I put a 3HP 3PH Inverter Special motor on it, with an inverter. It is almost impossible to stall, runs smoothly with almost any off-balance turning, and when you turn the speed pot up, it'll go from zero to OMG!!!!.
I subsequently got a Vicmark VL300, and have used that for my production lathe, but the Ol' Oliver still looks good on the other wall of the turning area.
Hope yours works out as well for you.
Doug Trembath
Lyle Jamieson
Lyle Jamieson
It looks good and you can brag that you have an oliver. But what have you got?? Reeves drive variable speed, that will not go slow enough, limited 12 inch swing, three phase power. Yes, all these things can be fixed but what have you got to show for the considerable cost to upgrade?? An OLD lathe that has been upgraded!! Been there done that...once. Dont waste your time or energy. Buy a good lathe, I have more fun turning then upgrading lathes. The money will be a wash, at best.
I'll be realistic...
a bed extension for my Jet 1642 would be more useful. The only thing I would want a 72" lathe for (other than bragging rights) is to turn columns.
Lyle Jamieson
Re: I'll be realistic...
Lyle Jamieson
The difference between 12 and 16 inch swing is huge. The difference between a 1 inch and a 1 1/4 inch spindle is huge. The bed length is seldom an issue unless you do architectural work.
I could not agree with Lyle more. My first home restored lathe had a 1"x 12 thread. A friend rebuilt the spindle for me and resized it to 1 1/4x8. I noticed the vibration reduction on larger pieces immediately. I had also converted the lathe from 12" swing to 16" swing using MDF riser blocks and added a DC motor.
As Lyle said earlier, I should have just bought a bigger lathe. As a learning experience it was wonderful. It's kind of like building your own home. Everyone I talked to who has done it said it was great experience that they they never want to do again.
I agree, but...
Doug Trembath
Like John, I was always looking for BIGGER when I was first getting into turning. Like him, I elevated a Delta 12" lathe to 18" by adding riser blocks. (Mine were Acrylic that I found at a plastic supply outfit. Looked cool, being transparent, and easy to mill with standard woodworking tools.) Like him I added a DC motor, to get variable speed and reversing. Burned out three of the control boards...
Then I found the Oliver, and built the lathe. Now, keep in mind, I used 1" and 1-1/4" steel plate, 4"X14" box tubing with 1/2" wall thickness for the risers, and had a friend machine all of the surfaces and bore the holes for bolt-up on a CNC machine. If I had had to pay for that, it would have cost more than the lathe was worth.
I then bolted on 3-7/16" Pillow Block bearings, had an old valve stem turned down as a spindle, reduced to 1-1/4" thread on both ends, had it gun drilled and a #2 Morse Taper cut in, and put it all together. When I was done, I had a rock solid lathe that will turn 24.5" over the bed, and have turned columns 5 feet long, 20" in diameter on it, as well as many bowls and hollow forms. It worked great, but I wanted a short-bed lathe, and got the Vicmarc, so unless I need to turn something longer than 20 inches or so, I use that, but I would hesitate to lose the Ol' Oliver, for those things it's really good for. I have moved the lathe three times since, it comes apart in five pieces, and has to weigh more than 2000 pounds assembled.
Would I do it again now?
Only if I had a need...
When I was finished, I had less than $2,000 in it, and could well have used it forever.
Not recommending you do all of that, just one man's experience in going too far in his search for BIGGER lathes. In your case, as the lathe stands, it will probably not be a good purchase for general woodturning. That's what I believe Lyle is saying, you can get a much more versatile lathe with much less difficulty that you would probably enjoy much more by looking at something a bit more conventional. Pattern making is a much different undertaking, and that's what these were designed and sold for.
I really like the 3520B Mustard Monster! Nice lathe at a fair price!
I'll stick with the Vic, though. It fits me and my work.
Doug Trembath
