THE WOODRAT IS BACK!
OT: Too much technology RANT!
Steven Antonucci
steven antonucci
I just got a call from the dealership. I've had a couple of tire issues with the air leaking out of the passenger side rear of my pick-up truck. Wife brought it in to have them look at it, and nothing wrong with the tire, so I drove it away.
Coming back from Totally Turning, the idiot light came on right before I got on the highway. I had about 10PSI left in the tire, so I refilled it and kept my fingers crossed. Made it home, no issues. The next day, it was flat again. Filled it and drove it to the dealership today.
The issue is that the TPMS is leaking. What's a TPMS, you ask? It's the %^$%*& that tells you that you have a flat tire! Tire pressure monitoring system is essentially an intelligent valve stem. The cost to fix it? $190.
For a valve stem. With a computer in it. That has decided to let the air out of my tire for some reason. After 6 years.
AAAAARRRRRRGGGGGGGHHHHHH!
I can see another 1969 Chevelle in my future. Soon.
Steve
Re: OT: Too much technology RANT!
Steven Antonucci
for my drive to Reston, VA tomorrow...no choice
steven antonucci
Re: make sure it has a skull and crossbones on it
matt overton
You're actually lucky the TPMS worked ....
JamieDonaldson
...for that long, as the batteries have an average life expectancy of 5 yrs. :\
Steven Antonucci
only one wheel, so I can expect 3 more of these?
steven antonucci
Steven Antonucci
Look silly on a Chevelle, no?
steven antonucci
Not that I have ever done something like that...
S
Re: only one wheel, so I can expect 3 more of thes *LINK*
Galen Vetterick
I have a month old Honda Accord with these sensors. Great! More cost down the road. Had them in a Chevy but they were internal to the tire rim.
I always worried if they would damage them when installing new tires. Chevy's worked fine but time will tell on the Honda.
Your comments made me look for articles on the subject. Looks like parts can be replaced.
http://www.tirereview.com/Article/59497/selling_safety_tpms_valve_stems_and_service_more_than_just_good_business.aspx
Steve I got in my car the other day and the key wouldn't work. The alarm kept blinking so they chip in the key obviously wasn't working. To reset the key you have to turn the key on an then back off. It would not move. fortunately I was home. I got my son's key. It worked. That evening I tried my key again. It worked perfectly.
so what the heck are you supposed to do if your out in the boonies and your car won't start because the fricken key doesn't think straight. I hate all the electronic crap. It's totally unnecessary and only there to make money for the dealership. I payed $40 for an extra key and that was aftermarket. That's the key that actually worked. The $80 key is the one that didn't.
Bernie Weishapl
I hate those things Steve. I have a Town and Country that the right front tire does the same thing. Cost $237 to fix. So I just kept putting air in it since it would take 2 to 3 weeks to go down. We traded it off last week. Sucks for sure.
Re: Look silly on a Chevelle, no?
matt overton
not with you at the wheel.
Steven Antonucci
I looked for a picture of the hood yesterday
steven antonucci
I have one somewhere, but I could only find the side profile. I had forgotten about the smiley faces on the doors. :)
Ahh, the good old days when I could afford to drive something that got 8 MPG, 12 if I let off the gas for a bit...
S
Ricc havens
Steve, before you pay the $190 check a regular tire dealer like a Goodyear store. My wife hit a piece of metal that cut the sidewall of the tire on her 2011 Subaru. I didn't want to driver 40min to the nearest Subaru dealer especially when I found they didn't have a replacment tire in stock. Went 5 miles to the local tire shop that is a Goodyear dealer but can get any brand. he said if the TPMS valve stem got damaged and needed replacing that they could replace it and the replacement would be $125. Luckily when they took the tire off the rim the TPMS was undamaged
Good Luck
Ricc
Spence
Re: OT Is there some reason
Spence
That you can't replace this thing with a regular old fashioned stem?
If the TPMS unit is not operating correctly,   ...
JamieDonaldson
...then you need a piece of "official" Click and Clack black tape to cover the flashing warning light on the dash! :D
Steven Antonucci
I'm an engineer,so I was just going to pull a fuse
steven antonucci
But Jamie is right... it needs to see 4 tires or it goes nutso...
I googled it and knew I was screwed from all of the gearheads on the Nissan Forums saying that you had to just fix it...
S
Re: I'm an engineer,so I was just going to pull a
Ken Ward
I turned wrenches for over 30 yrs untill it got so you had to have a fortune in testing equip just to look at somebodys veh.finally just said to heck with it.Oh well no sense b@#$%g about it.
Jesper, Denmark
Jesper, Denmark
It seems to me that the version of TPMS with a fancy valve stem is - like Charlie Belden refers to in another post - a PT Barnum trick. In other words a way to extract more money from the consumer with dubious benefit.
Who needs it? If you have a real puncture, you will know anyway and the prudent driver will check hi or her tire pressures regularly and find a slow leak that way.
On the other hand, MODERN vehicles use the information already in the ABS/EPS system to detect that one wheel has a different rolling radius, thus providing the warning function with no additional hardware.
Having my struts replaced today for $620. Remember when you could replace your shocks yourself for about $20 each. My 63 ford falcon got as good a gas mileage as my Honda, didn't handle all that bad and you could work on all of it with a $20 set of wrenches. I know, I did.
