ADVERTISE HERE - FREE TRIAL
OT Wireless and Wired Modem
Stuart Johnson
We presently use a Netgear modem/router for wireless connection. It sits close to my computer and I get a very strong signal. My wife's computer is a couple rooms away and her signal goes up and down. Sometime it's good other times she can barely get internet access.
Would her reception be better if I hook mine up with a wire and left her's wireless? Can this even be done? If not or there wouldn't be any improvement can a second modem/router be plugged into a different jack using the same DSL line?
Re: OT Wireless and Wired Modem
woodenleg
We are using NETGEAR in our house. The main computer is hooked by wire and we can get wifi anywhere in the house and outside. My neighbors have no trouble using our wifi ( the call over to get permission ). They are roughly 200' from the house. Hope this helps. Dave
Dave Paine
Wireless can be a challenge.
It is not as simple as which brand of Router. Also need to know the brand of the card/chip in the computer, the version of the wireless specification "b" vs "g" vs "n".
The latest is "n". This is potentially the fastest, being the most recent, but also it does better at reflecting the signals off walls, etc.
"a", "b" and "g" are more line-of-site and if walls the in the line-of-site the signal can be degraded.
Last year I installed a broad band amplifier in my house, so that I had improved signal strength and bandwith for steaming Netflix TV or movies and also to improve my neighbors signal.
The amplifier improved the signal in the house, and for the neighbor, but the bandwith at her connection was still less than desired.
So I also installed a higher power EnGenious radio (USB connection) on my neighbor's PC and now she is getting 120 Mbps and over 70% signal strength over the distance.
The issue is not the number of people connected, but how well your Router and computers interact.
I have a Dell ZINO which is nominally "n" band wireless. This does not perform to the stated speed. I have this connected to a DLink bridge which almost doubles the performance since I have a DLink "n" router.
The best performance is if the router and card/chip in the computer are from the same manufacturer.
The EnGenious USB radio was inexpensive. Do a Google search and take a look. This is being used on a really old Dell desktop.
Mark Wollschlager
Hooking your computer up with a wire will ensure your connection is always good.
For your wife it is a bit more complicated. Hooking yours up will not effect her signal.
A couple of rooms away could be a lot, depending on the distance, composition of the walls, and the orientation of the wireless antennas.
The wireless signal will work best through open air.
Every wall the signal penetrates will knock off a percentage of the signal strength.
Regular drywall is pretty transparent, but brick, block, or solid wood have more effect on the signal.
In some cases reorienting the modem and/or your wifes computer can make a big difference.
Placing the wireless modem up above obstructions is one method, also turning the modem or changing the direction of the antennas ( if there are any ) . Just turning the wireless modem, or your wifes computer while watching the signal strength. ( think rotating your TV antenna on the roof :-) )
Most modems with antennas work best when they are upright, not parallel with the ground.
Double antennas work best like \ / triple antennas work better \ | /.
If there is a connector between the antenna and the modem, make sure it is tight ( finger tight ).
Another, more technical solution may be related to competing wireless networks in your neighborhood.
If your computer can see multiple wireless networks in your vicinity there may be contention for channels.
Wireless networks operate on a number of channels ( 1- 11 ) 1 or 6 is pretty commonly used.
Changing the channel on the modem can sometimes fix a connection problem, but it may be more trouble than it is worth if you do not have access to the setup of the wireless modem.
Anyhow, hope this helps.
mark
Steven Antonucci
Similar issue at my house
steven antonucci
My router finally gave out after 11 years of service, and I had to replace it with a new N router. Turns out that I should have done it years ago...
I think that some of the older ones have issues with newer wireless cards and devices, and some of the newer routers have issues with some of the older cards. when I bought the new router, my new laptop started flying. So did my PC's, XBox, Wii, iPods, Kindles, and every other Internet enable device...except an old PC. Bought a new wireless card for it, and it's humming...
If you plug the PC into the router and it's fast, it's not the PC. If you move the PC closer to get a better signal, and it's still slow, try putting a new wireless card in it.
Steve
Jorge Casta�eda
Stuart,
I have the Netgear n router with a USB wire to my ancient Dell 4600, all my four ladies, have laptops, and use them sometimes quite far from the house, in the field, garden or the woods and anywhere on the house and I see the "excellent signal" display in all of them while my dinosaur complains of a marginal connection...
Do a test with a couple different laptops, recent ones and I think you will get a good signal. Maybe replace the card in the laptop if possible or replace the laptop.
Jeff Rich
Channel interference has been my biggest problem.
I have some wireless cameras and there are a few wireless networks in the area.
I had to play around with the channels for a day or two to see which one worked best.
Re: OT Wireless and Wired Modem thanks
Stuart Johnson
Thanks everyone for all of the suggestions. Once again all is working well. After a call to AT&T which involved no more than shutting down and disconnecting all cables and wires and then hooking it all up and restarting it's fixed for now.
The CNET article was interesting. Maybe if I just power down the router at night it will solve some of the issues I have been having.
