courtesy of Paul Stafford. My take on one of his little pill boxes. I've been wanting to make one of these for my bulk antacid tablets, buying them by the roll is rather expensive. How do you carry them and not look strange?
I liked Paul's idea of decorating the lid. I decided I wanted to simplify the turning process a little bit though. So instead of reversing the lid, I bored it out to final size & added a recess for a copper lid, Jennifer style, she would have made it prettier though So then I parted off the lid & did the rest pretty much as Paul explained in the article. The copper disk is my first attempt at something akin to repousse. The wood is Yellow Birch.
Repousse is an interesting process - that was very popular in the 1950s. The fun part is to keep the areas adjacent to where you're stretching the metal from deforming - especially when you want to keep it a specific shape - like your round disk. One method metal workers came up with is a Pitch Block. It's a cast iron hemisphere, filled with asphalt.
If you melt the surface of the asphalt, you get a smooth flat surface, which when cooled, is fairly hard. If you heat the metal you want to work, and press it on the asphalt surface, it will stick nice and flat, and stay there until you heat it again to remove it.
The hemispherical Pitch Block, when seated in a weighted leather "donut", can be tilted in any direction, and stay there. So you can manipulate the block to make it easier to work on your metal. Between the weight of the cast iron pitch block and the weight of the weighted leather "donut",you have a lot of inertia to resist any forces you apply on the repousse tools.
The interesting thing about this asphalt is that it remains elastic - not very elastic - but elastic enough to move a little when enough force is applied to it - like that applied by a repousse tool struck with a small hammer.
The neat thing about copper is that it's easy to discolor - with heat, chemicals or both. This allows you to emphasize either raised areas of the repoussed piece by darkening the low areas. A pea sized piece of Liver Of Sulfur dissolved in an ounce of water gives you an "oxidizing" solution you can paint on areas you want darkened. Applied to room temperature copper, it will produce a brown color which will get darker if applied to a warmer surface. If the treated surface is heated, the color darkens. Repeated applications and heating will produce an almost flat black look.
Jewelry making suppliers (Geshwein, Rio Grande), in addition to carrying chemical patina solutions, also have paint solutions that have the look of various chemical patinas - handy since the Liver of Sulfur solution smells like rotten eggs ; )
Repousse (working from the back to raise areas), combined with Chasing (working from the front to push back areas), can be a lot of fun to play with and the results can be really interesting, sometimes even beautiful.
And once you have acquired the tools and learned how to use them - there's ANOTHER possibility!
If you compress wood - say to smash the grain down - in a line
- remove the "high" wood - down to the bottom of the recessed line
- and then dampen the surface
- the compressed wood will swell up back to its uncompressed size.
Then
- you have a raised line on the surface of the wood!
This would be a lot easier than carving down the "field" around where you want a raised line.
Imagine a piece with subtle raised veins or some other raised pattern. With the right wood, this can be done!
Hi Charlie, your input is greatly valued. I realize that I have only just scratched the surface, so to speak. I have experimented some with heat coloring, enough to realize my torch is too big. I have also been collecting info on patina solutions, but haven't bought any chemicals yet. Just had to try out the little doming block & punches I bought at the Harbor Freight walk-in in town & some very old jewelers stuff I bought long ago.
Like roofing asphalt? Do you carve the shape you want into it? Reworkable & infinitely variable... not a lot of wood moulds & dies cluttering the shop?
I have a few pieces of vintage repousse & a piece I bought at a local craft show a couple of years ago. Amazing what can be done, if one knows what one is doing.
Doing repousse in wood is an interesting concept. A reverse effect from the fancy compressed moulding in the borg stores... hmm.
I'm very seriously considering that my next lathe might be a metal working unit with a milling attachment. It would be much easier I think to make most tooling for this.
Carvers have been pounding dimples into the back of a frog, sanding the frog back down to a smooth surface and then steaming to "reconstitute little bumps on the frog back.
I have used leather stamps with a 4 ton press to impress a pattern. Cut and sand the stamped area smooth then steam the pattern to raise stamped pattern back up.
The wood species used is important. You want a wood that is compressible where the fibers won't break. Dense and open grain wood don't work well. Grain direction is also of concern. Because the effect is subtle it is better done on plain looking wood.
While the effect can be interesting it is still "art". The effect is no better than the artistic effort put into it. In other words, if the effect done for effect sake is nearly worthless.
Very nice and functional too! Did you carve out the pattern for the "repousse" on a piece of wood and then hammer the copper into it? That's something that I need to try. It's an old technique that's discussed in some books. What gauge copper are you using?
Thank you, Jen, I used 25 gauge sheet for that disk. If I was smart, I would have carved the pattern then hammered into it. I've read just a little about that method. I made the central part on a little doming block. For the petals I ground the end of a 5/16" bolt to that shape & just hammered against a soft pine block. Had I taken the time to do an intaglio carving in a hard wood, I'm sure I would have gotten crisper results. I'm very intrigued by Charlie's talk about the asphalt ball, although I'm going to guess that works better with thinner stock. 25 gauge is still surprisingly stiff. I cut the disk out of the sheet with an old heavy duty gasket punch & hammer. I'll post some pics of some of the odd tools I've collected for doing this, later this week.
It was a fun & challenging little box. I've never attempted anything so delicate or with such close tolerances.
at the 2010 Woodworking In America conference. If I remember right, it was an Old Country trick that Frank was using to to raise a bead as a seal between a box bottom and its sides -- which were of course dovetailed together. [Okay, sorry about interjecting that flat-work comment -- just thought it was neat that these different cultures were using essentially the same technique.] That was the first time I remember seeing that trick, but then again maybe I don't get out so much.
