New Work 2
New Work 2
New Work 2
Steve Criscenzo
This is a bowl turned from a Poplar log that had been sitting outdoors for a while. I was about to toss it into the burn pile but decided to give it a look. Glad I did.
The bowl is about 14" in diameter. The bark inclusion was a surprise. After I saw it, I reoriented the turning to give it more of a focus. Used coffee grounds to fill in some voids after drying. Finish is several coats of tung oil and then buffed.
Comments on the bowl or photo appreciated.
Steve
Re: New Work 2
Your lighting set-up is well.......
JamieDonaldson
..diffused, maybe too much so on the pepper grinder. With it mounted directly above the bowl, there is some lack of shadow detail around the base, but more importantly, there are no hints of a shadow to add a sense of depth to the image of the grinder. Have you tried moving the light off a bit to the side and lower?
Re: New Work 2
Re: Your lighting set-up is well.......
Steve Criscenzo
Jamie
Thanks for your hints. I guess I tried too hard to eliminate the shadows. I also had a hard time getting rid of the glare on the pepper mill. (I am sure it was the ultra smooth finish.) I will play with the light some more and see if I can get some depth.
Steve
