new member book...
GaryG in MD
One of our WC family, Doc Green, has a new book out, titled "Fixtures and Chucks for Woodturning". It's available on Amazon for a quite-reasonable price. Check it out. (No commercial connection, etc....), Gary
new member book...
GaryG in MD
Re: new member book...
Alan Zenreich
Thanks for the heads up. I just placed an order... should be here on Tuesday
A description of the book
Doc Green
Yep, Gary, today's the day - the official release date of the book by Fox Chapel Publishing.
The book begins by describing the basic methods for using drive centers, faceplates, and scroll chucks. Chapter 4 deals with waste blocks, glue blocks, and small screw chucks for turning knobs, for example.
Chapter 5 gives a fairly in-depth description of jam chucks. It includes a section on making fixtures for the live center to use in conjunction with a jam chuck mounted on the headstock. Chapter 6 deals with mandrels and collets. The basic procedure for turning a pen is given.
Detailed instructions for making a doughnut (compression) chuck and a Longworth chuck are given in Chapter 7, along with the applications of Cole jaws.
Vacuum systems are covered in Chapter 8. Detailed instructions are given for putting a system together (using a vacuum pump). Particular emphasis is given to making the coupler that connects the vacuum line to the rotating headstock spindle. Three different designs are given, and none require any significant metal work. Couplers are described for the PM 3520 and Jet mini lathes. Chapter 9 is devoted to making vacuum chucks of various sorts.
Steady rests are described in Chapter 10. These range from small spindle steadys to a rather large vertical-post steady that is super strong (Thanks to Herman de Vries, of WoW.) Also, a couple of string steadys are described that are useful for turning goblets with very long stems, trembleurs, and so forth, and a similar steady uses clothespins instead of string. Two designs for bowl steadys (for vibration damping) are given.
The last two chapters deal with applications. Included are instructions for attaching a foot or rim to a bowl, the basic procedure for making a box with a lid, turning a ball, tree ornament, candle holder, and so forth. One section gives procedures for turning small parts that may become part of a finial or part of the base for an elevated vessel, for example. One method of hollowing a vessel through the bottom is given.
A major portion of the book is devoted to step-by-step projects that illustrate the chucking methods. Because of length considerations, topics such as tool manipulation, sharpening, and sanding are not covered - one book cannot include everything - because these topics are described in other books and websites.
I owe a major debt of gratitude to the many people who answered questions for me a year or so ago when I was assembling the information that was to become this book. Because of your willingness to share information on your preferences as well as technical matters, this book is more in tune with the real world of woodturning than it otherwise ever could have been.
Thanks for your interest. ~Doc PS: You can find the book by doing the Google using "Doc Green woodturner" or "Fixtures and Chucks."
Re: A description of the book
Dick Hines
Doc, you have holding out on us.
I knew him before he was a famous author
GaryG in MD
It's in my Shopping Cart. ...Gary
Howard Norman
I ordered the book from Amazon yesterday. Should be here this week.
howard
Doc's book arrived today
Alan Zenreich
The book arrived from Amazon today.
I thumbed through the pages... and first impressions are very good.
The book has lots of photographs and instructions for real world solutions to real world problems.
This is a first rate production, so thanks to Doc and all those involved in getting this to print.
Bob Moffett
Doc, congratulations, I didn't know I knew a famous woodturning author.
Ken Ward
Looks like I might just be adding another book to my collection
Re: Doc's book arrived today
Howard Norman
My copy arrived today from Amazon. I concur, the book is well done and I have already picked up a couple of good pointers.
howard
