Recommended adhesive question
Ed Moore in SW VA
There is a recommended adhesive when placing small mirrors into wooden backs that have been turned for them. What is that adhesive?
TIA,
Ed
Ed Moore in SW VA
TIA,
Ed
Re: Recommended adhesive question
Jennifer Indy.USA
Ed I've been using liquid nails or even silicone out of the squeeze tube. One of my rotations last weekend was making a turned mirror with an inset copper wrapped mirror.
Jen
Ed Moore in SW VA
So you have had no problem with using the Liquid Nails for Mirrors?
BTW, congratulations on the extremely positive reports on your demos at Totally Turning. I am happy for you in many ways.
Ed
Don at Central Illinois
I believe John Lucas uses silicone.
Rob Cohen
Silicone is the standard for this
Ed Use clear silicone caulking. I have tried other glues and this is by far the best. I purchases some official mirror adhesive at $8 for 6oz tube. It looks and smells just like clear silicone caulking that you can buy for $5 for a large tube.
don't use liquid nails. I had a bunch of failures when I tried that stuff. the funny part was it stuck to the glass and not the wood.
Thank you!
Ed Moore in SW VA
I don't need failures.
Silicone it is!
Ed
Alan Zenreich
Have there been any interactions between the adhesives mentioned here and the silver mirror backing?
We don't want it to desilver the mirror over time, so I'm interested in the long term effects on the reflective material.
Does anyone know what the professional mirror installers use?
Alan Zenreich
In my 'instant research' I came across Locktite PL Mirror Mastic adhesive.
Anyone have experience with this?
http://www.acehardware.com/product/index.jsp?productId=2923269
Alan So far nothing I've tried has affected the mirror backing. I've been using the clear silicone caulk for almost 20 years. I still have one of the first mirrors I made.
I have looked for alternatives. not because the silicone caulk doesn't work, but because I end up throwing away 1/4 to half a tube because it just gets too hard to clean out the tip. Elmers f-26 works wells but is way to expensive. I've tried bathtub caulk and things like that. They don't work. I mentioned liquid nails. It didn't work.
The best way I've found to keep the tip from clogging is to wrap masking tape around the tip leaving extra room beyond the tip. the squirt some caulk into the tape and then close off the tape. This extra caulk is what hardens and usually you can grab this and pull out any that has hardened inside the along with the extra caulk. I've tried nails, screws, wire twist as caps and several other recommendations by others. My method works the best so far.
Thanks John. I just ...
Ed Moore in SW VA
got back from returning the Liquid Nails Mirror adhesive and getting some small tubes of clear silicon at Lowe's.
Thanks for your help. I would probably have learned this at your BRW demo if I had had the energy to attend. I'm learning that there are some things in life that one just doesn't bounce back from very quickly. I looked in the mirror yesterday and I was about the color of hawk meat.
Ed
Jennifer Indy.USA
Ed, thanks...it was a fun weekend!
I've never had a problem with the Liquid Nails. When I cut the recess for the mirror I use a thin parting tool or whatever tool I have handy and make a bunch of groves where the mirror will go. It just gives some "tooth" for the adhesive to cling to. I've used Liquid Nails to hold a giant bathroom mirror to the wall before. I can't imagine in this application it would fail? Not sure how or why John's did?
Jen
R. Payne
From working construction where liquid nails was frequently used, I know of some of the failure modes for it. One is waiting too long to put the two pieces together. Liquid nails will skin over fairly quick and the skin won't stick to anything. Another is temperature. If it gets too cold liquid nails doesn't like to stick to much.
ron
I put up some mirrors recently....
I am racking my brain for what ever the stuff was the glass company sold me at an outrageous price for the job, but when I used it, it was suspiciously like silicon. I can call them tomorrow and double check if you want, but I think you can't go wrong with silicon.
Re: I put up some mirrors recently....
About the only downside is the cure time. You have to either lay the object down so it won't move or if it's vertical, clamp it in position. I usually just glue my mirror blanks in and let them sit for 5 minutes before moving them. Then I'll lay them flat somewhere until the next morning.
There is one more thing that works. Foam backed double stick tape. It's quick, easy, and not messy. I'm not sure why don't use it, other than I never have it on hand but a role is not expensive. I don't have any long term results but I've pulled mirrors and tiles off of wall of homes and they apparently used the tape on these with success.
Re:BE SURE OF THIS
Don Evans
There are more than one type of silicon, note here in this thread that one person will say that doesn't work for them and another will that that does work etc etc!
Terminologies may be the culprit at work....
For this application you want to make sure the tube you are getting says -- "silicone" also "chaulking/adhesive" then check for it's color which in this case should be "clear".
I may be wrong, but I've never seen anything but "clear" that was also rated as an "adhesive". But I have seen clear that didn't say "adhesive", so be sure you're getting the right thing.
On the nails stuff, I've never used it but I'll bet the trouble is with skimming over before the parts are brought into contact with each other as already mentioned. I mention this because you can have the same problem "time lag" with the silicone adhesive if not carefull and ready to slap the mirror in soon as the silicone is applied.
E6000 is another good adhesive for this application and is more available that when I first started using it. Even Michaels carries it. If really desparate you can find it in a pack of round sanding disk at Lowe's now.
Don
Re:BE SURE OF THIS
don Skimming over of Liquid nails was not the problem. I've glued panels to wall with it and it takes 30 seconds to a minute to put enough adhesive down to get the panel ready. With the mirrors it takes about 5 seconds to put a few drops down and then the glass.
There are probably a lot of adhesives that work. As I said Elmers f26 works but it's $2.50 for a very small tube.
Anything that is flexible and stays flexible and doesn't degrade the mirror back will work.
Re:BE SURE OF THIS
Rob Cohen
I believe the glass guys use a GE industrial silicone that has a very short setup time
