CA, Pen Bushings and $6.50
Stuart Johnson
I'm in the process of turning 20 + pens for the local librarians as gifts for the upcoming Library week and I had a problem. I screwed up a $6.50 stabilize burl pen. All went well through the turning and finishing. The finish was sand to 400, CA applied, re-sand to 1000. All went well to this point. When I tried to take the blanks off the bushings they were stuck (CA glue). I could not get two of bushing loose. In the process of trying to apply pressure and breaking the joint I ended up cracking the blank. $6.50 down the drain.
How do you keep the bushings to from sticking to the blanks?
Re: CA, Pen Bushings and $6.50
Jim in Burlington Ont.
Jim in River Oaks, Ont.
That hurts Ouch...
I use a paraffin wax candle, I rub the bushings with it and I am fine.
Another way to remove the bushings when attached is to remove the blank from your mandrel and use CA remover, soak the ends at the bushing interface, take a safety razor and score the contact between the two, you might have to redo your finish, but you will save the blank. Just my experience
Take care,
Jim
Todd Nebel
I saw this technique on a youtube video and it has worked for me so far. Slide the bushing to the end of the mandel where the threads are. The threads are narrower than the shaft and if you apply pressure here it will break the glue joint but not allow it to go so far as to pull on the wood to the point to chip it. I hope I explained that clear enough.
paraffin wax
Todd Nebel
Hi Jim, thanks for the paraffin wax tip.
David Walser
Stuart,
I've had the same problem. I tried coating the bushings with Renaissance Wax (since it's handy in my shop), and that helped some. In addition, I mount my magnifying light onto the lathe and, looking through the magnifying glass, carefully use my sharpest skew to slightly chamfer the end of each pen blank where it meets the bushing. The chamfer begins less than 1/64" from the end of the blank and is so shallow it doesn't go through all the layers of CA glue/finish. (Your eyes may be strong enough you can chamfer the blank without nicking the bushing or cutting too deeply into the blank without the magnifying glass, mine aren't.) With both wax a slight chamfer, I've been able to remove the bushing with a simple twist.
Another reason for chamfering the blank is it seems to help the parts mate up together better. If I've sanded the blank down flush with the bushing before applying the CA glue/finish, the blank will be slightly proud of the bushing by the time I've built up a decent finish. Simply snapping the bushing off (or scoring with a knife between bushing and blank) will sometimes leave a sharp edge on the blank that you can feel after the pen's assembled. The chamfer eliminates this sharp edge.
Good luck and I hope this helps!
Alan Zenreich
Alan Zenreich
Two other approaches:
Use delrin bushings for finishing
or
Get rid of the bushings entirely and finish between centers
Scott Crumpton
This is more of a question or a why not try this than any first hand knowledge on my part as I've yet to turn a pen. David Ellsworth glues the cutters into his hollowing tools with CA and says that you simply heat the bar to remove an old cutter. I don't know to what temp. But might it possible to heat the bushing by placing it against a hot surface until the CA at the joint softens and then remove the bushing before the finish gets damaged further?
ken ward
Don't know if this was mentioned,if so sorry,But I had the same problem,tried the wax and still stuck,although I did get them apart with out breaking them,but what I do now is sand to 600,then take the blank loose from the bushing THEN I apply the wax to the bushings,then to the very ends of the blanks being carefull not to get any on the outside,even put a bit on the inside of the pen tube and havn't had one stick since I started this.
Wax paper
Ron McKinley
I saw on the IAP forum that someone uses wax paper to protect the bushings during finishing with CA. Haven't tried it but it sounds like it would work....Ron
Keith Inscho
+1 on the paraffin, and you can also run a razor blade around the bushing about a 32nd away from the pen blank then pop it off and clean up the end.
Doug Turner
I make bushings out of Delrin plastic when using CA finish. CA and epoxy won't stixk to it, and it is very durable.
