Delta Variable Speed grinder
Carole Valentine
Anyone use this grinder? Comments? Can the light be removed?
Re: Delta Variable Speed grinder
Rob Cohen
I do use this grinder and it's ok for the money. Definitely not as smooth as a Baldor. Be aware
that their quality control is only fair. I had to exchange the first one I got as it ran pretty rough
even after playing with the wheels a bit. (Delta was more than helpful) 2nd one has been fine for a couple of years.
The light is attached at the back near the base and I would think it would be easy to remove.
Mine is attached to a board with the wolverine system so I can't actually see it.
Certainly as good as the other Chinese made slow speed grinders and it gives you speed options as well.
Rob
Mike Peace
Mike Peace
I had the six inch Delta variable speed. The electronics burned out so it would not work. Not cost effective to have it repaired. I replaced it with the Woodcraft 8" low speed grinedr. I am not sure I see a big advantage in a variable speed if it varies from 1750 to 3500 and I am only going to use it at 1750. Especially if it makes it more likely to break.
john lopez
Carole,
I bought a reconditioned 8 in. vs Delta from Rockler on sale.
I've had a few problems with it over a 5 year period.
The on / off switch failed ...
lucky for me it quit working in the power "on" mode.
I think dust may have ruined the contacts inside .
It's probably an easy fix and sooner or later...
It's bolted down and way too heavy for me to move so
now I use a dedicated power strip with an on / off switch
attached and within easy reach, mounted on the rolling base.
I have a Veritas tool rest on one wheel and the standard
platform on the other.
I also have Kelton Multi Grind sockets mounted on both sides
for times when I'm not freehand grinding
The wheels run true and get dressed with an included
t-handle diamond dresser.
One of the hinged eye shields fell apart almost immediately.
I use a trend air shield so my face and lungs are protected.
So far no complaints about the small gooseneck lamp.
I just bend the flex arm to get it out of the way
as needed.
I run the speed at the slowest setting all the time.
The vs feature works but does not get used often.
I think it wise to consider all options before buying.
J.L.
Carole Valentine
John,
Did you get the GR450 or the Delta Industrial? The GR450 VS weighs 48 pounds but the Industrial model (if they still make it) weighs 100 lbs. That is way to heavy for me as well! 50 lbs is about my limit.
john lopez
I have the GR450R , the housing & motor seem quite solid.
My shop made base makes it heavy enough to lean on while
I'm grinding.
That gives me more stability and control.
Carole Valentine
Think the R just means reconditioned. There is Type 1 and Type 2 and I still have not figured out the difference between those.
I was expecting to have another Woodcraft in my shop tomorrow but then I started looking at the Delta with it's easier wheel change. I like the idea of being able to change the wheels a little easier.
Katherine Kowalski
Katherine Kowalski
Carole,
I do not personally own one, but some of my colleagues have said that the electronics on the Delta are exposed. Dust and metal filings will ruin them sooner or later. However, a couple of folks have had great success using a bit of cardboard and duct tape to seal everything inside.
Katherine
john lopez
Katherine,
that is pretty much the fix I had in mind for mine.
I was thinking the seal could be shoe goop.
Carole Valentine
Thanks for the tip, Katherine. If I get one I will seal it up before I put it to use. There really doesn't seem to be much out there in a range between the Woodcraft/Delta and the Baldor!
Bruce Smith
Carol I have the Delta variable speed grinder GR450 here for six years and haven't had any trouble
with it. The only thing I did to it is replace the grinding wheels with better quality Norton Blue wheels, this I new I would have to do before purchasing it as most grinders any this one is no different come equiped with second class wheels, one of the wheels on the GR450 is grey and the other is white friable.
I can't answer you question on the light issue as I have never had my grinder appart, but I would think it would be removable. At times I kind of wish that it had a little longer flexable arm on it, I wonder why you would want to remove it. I use it in the slow speed most of the time and rarely go above 3/4 speed, hope this helps with your decision, good luck.
I don't know the present cost......
JamieDonaldson
..differential, but a VS grinder is a non-beneficial option as far as I'm concerned. I've heard reports about the Delta having lack of power at the slower RPM's, and I still consider a well tuned Woodcraft 8" grinder as the best value for the money.
Re: I don't know the present cost......
Carole Valentine
Yeah Jamie...I have come to the same conclusion and have gone back to my original order for a Woodcraft and a couple of Norton wheels. I think a grinder may be a disposable option. I bought my first Woodcraft over 6 years ago for $75. Figure that is less than a nickle a day! LOL Apparently the newer version of the Woodcraft needs a couple of minor mods (bolt holes drilled in the base plate, cast iron leveled on the base so it doesn't rock, etc) that were not necessary on the older one. No big deal for the price.
Bill Blasic
Bill Blasic
Carole,
A very good grinder in between the ones you mention is the Dayton grinder. Check them out, they are the ones that Doug uses on his tools day in and out and he does not mess around.
Bill
Carole Valentine
Will definitely do that. The $90 grinder I got yesterday, though it was supposedly checked out before it was picked up, squeals like a pig when it comes up to speed and unless something changes when I change out the wheels, it is going back.
