Roughing and Coring some Ash.
Greg Haugen
Our city and county foresters are just starting their cutting season here in Wisconsin. The first trunk section was dropped off at the wood lot this week and it was a rather short piece of Ash. It yielded 9 slabs for bowls and I cored out 21 bowls out of them. The largest bowl in the center is 15" in diameter. There was also some pieces that will make good stock for hollow forms as well. These roughed out bowls are sealed with anchorseal and will go into my kiln for a month. Afterward I'll finish turn the bowls to their final shapes and thicknesses. They'll be ready then for someone's table.
Re: Roughing and Coring some Ash.
Looking good! What accounts for the color? I thought Ash was blonder, almost white.
A question. You seal them with Anchorseal AFTER you core them and then put them in a kiln? Seems counterintuitive. Doesn't the kiln drive the moisture out and the Anchor Seal attempt to retain it? Does the kiln melt it and drive it off?
bill Crommett
Greg: Did not Wisconsin have an embargo on Ash because of the Emerald Ash Borer ?
Steve Kubien
Steve Kubien
Barry, I won't speak for Greg but I DO use anchorseal on the end grain (inside and outside) of my bowls before I put them in my fridge-kiln. The idea is to equalize the moisture loss between the side and end grain and the anchorseal does this. If you don't, you can get severe cracks and checks. I wrote about my kiln and the no-nonsense approach I take to drying blanks on my blog.
Barry-Roughing and Coring some Ash.
Greg Haugen
Barry,
Some of the darkness you see is the anchorseal. Ash has a sapwood and heartwood like any other tree. Ash can be very white in the sapwood to a tan-brown color in the heartwood. This was also the bottom portion of the trunk and I've found that area to be more varied in color and figured. There is "white" ash trees and "Green" ash trees. Their wood is usually lumped together as "ash".
Yes, I seal them in anchorseal, except for the side on the inside of the bowl, after their cored when I put them in the kiln. Anchorseal does not "retain" the moisture, it simply evens out the rate the moisture leaves the side and end grain. If the bowl is over 1/2" thick, you have to do something to equalize the rate the moisture leaves the wood or it will just cracks. The kiln will only get up to about 85-88 degrees F during the final week. It doesn't do anything to the anchorseal. It's turned off during finish turning. I can put 65-70 bowls in the kiln. In four to five weeks, they'll be dry and maybe out of two or three full loads , I may lose one or two bowls (out of 180-210 bowls) to cracking. When I built the kiln the turner who gave me the instructions said he only sealed the outside of the bowls and nothing on the inside. The bowls would dry faster from the inside out. That worked ok but I would lose 3-5 bowls a load. Doing this way, I don't often use a bowl in a load. The kiln works the best, when it's fuller.
Bill- Roughing and Coring some Ash.
Greg Haugen
The EAB, emerald ash borer, attacks the tree through the back and cambium. The main issue is "firewood" companies that transport firewood across state lines, and/or "campers" that transport firewood when they travel. If the bark is off of the wood, there's no harm or threat. There's no fear or threat from "boards" of ash. This ash was literally cut down, down the street from us. There was no harm in bringing it home. Especially after I slabbed out what I wanted, including cutting off the bark and the scraps were burned on their bonfire. "Bark on" ash wood shouldn't cross state or county lines.
There is also treatment that has been proven to kill EAB that is put out by Arborsystems and that is in use as well. Hopefully they can take out the EAB.
Barry/Steve-Roughing and Coring some Ash.
Greg Haugen
My kiln is a little different than Steve's. I don't use any fans in mine. Just a light bulb; 40 watt, 60 W, and finishing with a 75 watt. A grid of holes in the top and bottom of the freezer. In 4-5 weeks the bowls will test out at approx. 7% moisture content. My style of kiln, isn't mine. It's from Kelly Dunn, an incredible woodturner from Hawaii. He recently posted his instructions on the AAW "newbie" forum when he responded to someone's post about drying bowls. The only thing I do different is, as I said, I do seal the endgrain on the inside as well as the whole outside.
