Trash can cyclone
Trash can cyclone
Trash can cyclone
Ken
I have a trash can cyclone that works great but, it leaks around the 4" hose connections. There are lots of results on a Google search but they all address a seal at the trash can. Has anyone here sealed the hose connections? Or have suggestions on how to do it? Thanks for any feedback.
Ken
Re: Trash can cyclone
Duct Tape
Dick Wilson
Dick Hines
Dick Hines
I cut the holes in the lid so I could imstall 4" couplers. Then pop riveted then into the trach can lid and then sealed then with caulking.. No more leaks.
Way back when I built my trash can cyclone, I caulked the "seam" between the PVC fitting and the metal lid. I cheated though - I used a 30 gallon drum with a flat lid.
Jim Sebring
I use quick disconnect fittings, since I use the DC on several different machines. I epoxied the male parts to the cyclone inlet and outlet points. The hose that connects to the DC (outlet) is permanently hose-clamped to one of the fittings. The other (inlet) side is where the hose from each machine, in turn, is attached. I got the QD fittings at Rockler. They're just a tapered push-on fitting and work very well.
pete labelle
Buy a couple 4" couplings. Insert half into the hole. Cut some wood spacers on at least 2 locations and thru bolt with some small bolts. Caulk with silicone. Mine has been working for 15 years now.
Two other tips:
1) Cut a 1" wide slot top to bottom, stopping short of the bottome & top by about 3". Cut a piece of 1/4" polycarb about 3" wide. With bolts every 3" on both sides, fasten the window to the inside of the can, then caulk with silicone. This is your sight glass to determine how full the can is. Once the can reaches about 2/3 full, empty it. Running fuller than that will cause more material to head to your DC bags. I'll empty my can 20 times for each bag change.
2) If not present from the factory, install a 2" wide strip of 1/2" thick foam to the sealing surface of the lid to the can.
Pete
