I am starting to like my new toys
Terry Scott
When turning I am continuously trying to improve my finish off the tool
This piece of Australian hard desert timber (yes the name was written on the blank but I forgot to note it down before the name went to saw dust Dam blast )
As I was turning one of my winged pieces the timber was being turned cross grain .
I was struggling a bit as I was getting allot of torn grain and this was causing chatter as the hit and miss soft hard grain
So I sharpened up my largest kelton hollower with a high prominent burr(pour tip will never be the same )The best cut was as shown with handle up in the air and the tip cutting below center almost at the point of the tool being cutting on the down ward stroke.I can hear the oh my god whats he doing.Dont worry I was in control not the tool
The stiffness of the tool enabled me to cut to 2mm 1/8 .Probably an over kill on a small box but I was just using a stroking cut and taking off the minimum I could
The next shot is showing the shavings not from the Kelton but a tool tip I have come up with (no you cannot see it l.o.l )as hopefully a tool manufacture will shortly be making them
I was surprised at the finish cleaned up like a babies bottom . Sanding with 120o wet and dry with oil was all that was needed.
I also found that the speed increased got a better cut about 1200 rpm
Tomorrow I will start on the lid and finial
Cheers
Re: I am starting to like my new toys
Re: I am starting woops wrong photos
Terry Scott
