Nova Chuck
Dick Hines
I just got my flier form Woodcraft. They have the SuperNova2 chucks on sale again $140+ insert.
I may have chuck #5 shortly
Nova Chuck
Dick Hines
S-N-2 is a Great Chuck
Brad Vietje
Re: Nova Chuck
Terry Scott
I have many super novas But are getting slacked off with them as the key ways that you place the tee bar into are wearing due to the round ended Allen key
Also have 4 Trition (no longer made )They are knackerd totally for the same reason and you cannot get parts .I guess you gets what you pay for.I herd a rummour this is why they stopped making them
Ive spoken to Teknatool but they say I am doing the chucks up to tight ,The Vicmarcs I have dont have this problem as the key way is much deeper .As I can afford it I will be up grading .In Nz Dollars the price is $289 so at 140 even with 25% difference in currency Cheep
ive always been loyal to Nz Made but know there in China I feel I can go elsewhere
Re: Nova Chuck
Bill Blasic
Terry,
The very first thing I do is throw away the ball ended key and get a flat ended one.
Bill
Re: Nova Chuck
Dick Hines
After I replaced the pinions in my SupreANova2 I went the the square ended allen wrench also.
Never did like the rounded end one.
Grind the round off the key!
Jorge Casta�eda
Terry,
From experience in other tools with round key noses, when I got the Supernova 2, first thing I did was to grind away the round. My chuck still is in good shape 4 years later.
That's what I did
Jeff Willaford
Re: Nova Chuck now you tell me l.o.l
Terry Scott
How can I repair the know rounded out hex Over the last couple of years Ive weeded out the super novas as the key system was hard to use
Replacing as many chucks as I have will take a while ,
Re: Nova Chuck
Barry
When you get a new Super Nova II, go buy yourself a standard T-handle Allen key to fit the chuck and throw the ball-end wrench that comes with the chuck away. That's what I did and I have never had problems with the chuck wearing prematurely.
Don't buy a new key
Carole Valentine
Just grind the ball off of the existing one. That's what I did.
Dick Hines
You can get the pinions form Teknatool. As I remember they were cheap. I do they are easy to install. And while you are at it you can give your chucks a good cleaning. Kind of like killing two birds with one stone.
Ok, I don't understand something...again
Steve Kubien
What is the problem with the ball-ended key? I have two SN2's and no apparent issues after 3-4 years. What ought I be looking for? Why should I grind the ball off the end of the key?
Re: Ok, I don't understand something...again
Doug Wolf
Steve,
I have 2 SN2's about 2 years old and the hex sockets have started rounding due to the hex ball having less surface in contact with the socket. When tightening the jaws, the hex ball puts too much pressure per square inch in the hex socket and slowly but surely will cut away the flats.
I finally cut the ball off my hex key before it gets any worse. Maybe I'm overtightening my jaws but I'd rather overtighten than be too loose.
Just insert your hex key into the socket, twist back and forth and see how much play you have.
Steve Kubien
Thanks Doug. I will do that (and possibly grind off my keys).
Little known fact....
Mike Stafford
The Vicmarc hex key fits in the SN2 and vice versa or the other way around in reverse....
Re: Nova Chuck
walta
Do you use your chucks key as a lever when removing the chuck from the lathes spindle?
Walta
Re: Nova Chuck
Terry Scott
when I cannot find my spanner on the floor
so yes guilty
Re: Nova Chuck
Doug Wolf
Never used the hex key but didn't have a wrench large enough so got my arc welder and some scrap and now I have a wrench to remove the chuck.
Re: Nova Chuck
Wayne Kuhn
Try a metal rod tightened across the jaws. Give it a good tug or a light impact and the chuck will loosen right up.
Wayne
Re: Nova Chuck
Ed Wujciak
Doesn't need to be a piece of metal. Scrap wood works fine and we all have lots of that.
