I'm not familiar with that particular lathe, but had a smaller Jet lathe with a manual speed. After you use it for a while it just becomes second nature and you don't even think about the changing of speeds. Sort of like shifting gears in a car. Some people think it might be a hassle but after a while you don't even consider it. On the other hand, having an electronic variable speed lathe is a nice feature. There again, once you have it....you would never regret the extra money spent on it. On thing that I do love about the EVS lathes is that you can spin them in reverse. Nice for some things like sanding. My advice to most people who are shopping for a good quality lathe is to buy as much as you can afford and you probably won't ever regret spending that money down the road. If you want a great place to shop for a lathe and enjoy a weekend of woodturning mayhem you should make the trip over to Saratoga Springs, NY for the Totally Turning Symposium this coming weekend. The trade show should have plenty of lathes for you to test drive!
With the advent of inverters and variable frequency drive systems one would be penny wise and dollar foolish not to get the EVS system on a lathe if it is available for the model you are considering. These systems maintain good torque at the lower turning speeds and they also allow you to go to very low speeds (50-75rpm). I find this extremely useful since I like to apply an oil finish onto the rotating piece. At the lowest rpm on most mechanically adjustable lathes (350-500rpm) the liquid finish will be slung off and you will be applying finish to your shop and yourself. Do you prefer the satin or glossy look when you look in the mirror???
I'm with Jen in that if you have a manual-speed-change lathe, you won't think about it after the first couple of days. That is certainly the case with my Nova.
As a side note, just because a lathe does not have EVS, does not mean it cannot reverse. My 8-speed Nova 1624 reverses and, again like Jen said, it is really nice for sanding. Personally, I view reverse as a more important feature than EVS by a long shot.
The Vega people are top notch, and I really like them. But that said, their lathes are just do not look like precision machines. On their bowl lathe, one place has a hex nut welded on instead of tapping the steel. It still spins wood, and they are built well. It's just some of the cosmetic things that are lacking.
I would never own a lathe without electronic variable speed. Unless of course you never plan on turning a bowl.
Steve I really didn't know that! The manual lathe that I had was a JET mini and I guess that's the only experience with a manual. I learned something today! Actually I've learned a lot today
My first lathe was a 4 speed Atlas, and belt changing for speed change took maybe 15 seconds. My next lathe was a PM 3520A model. I will never go back to changing belts again. The variable speed may be considered a luxury to some, but it is well worth it to me. I do not care for the variable speed thing on the Nova DVR, and 3 phase motors keep torque better than the DC motors. I have never turned on a Vega lathe.
