Damm I thought I had one of everything
Terry Scott
Just added another toy to my stable
and to think I thought I had one of everything
Today I decided to give the new Tool gate a work out and see what it was made of.
Ive been having trouble with some of the large overhangs I turn with getting vibration through the rest
A mate that has a Kelton Tool gate suggested I needed one.He wasn't wrong
First thing I did was use a hollower in the rest
No complaints there
Next I used the arm as a tool rest the flat top enabled me to slide the tool with ease
Next I got out big Bertha my scraper No Flex there either
For the finishing touches I use a cabinet scraper that I made from an old saw blade in the shape of an egg sanding can start at 320 grit after Ive used this baby
The bowl in the shots above is the second were I used the rest
Number one has developed a small problem
and wont hold soup
This amazing piece of wood quilted maple was to be one of my entries into the royal Easter show in the plain bowl category
Not to be
If anyone can tell me were I can get another piece of this wood or wants to part with some they have ,Ill swap this bowl l.o.l
The most amazing stuff I doubt if ill ever come across anymore like it
Back to the tool gate
if you havnt got one id recommend you need one .Ill be making a few modifications like adding a ring collect to the shaft to set the height and so I can swivel the arm in the rest. I will also grind the top off the collar so the tool can stay level when in line with the shaft a washer may also be needed to lift the gate
Otherwise this is another rock solid I cannot break it toy from Kelton that Ill enjoy using more in the future.
Just wish the tools were readily available here (maybe not or id be tempted to get everything in the range )
