Catches With A Hunter Tool
Stuart Johnson
For some reason I'm having a problem with catches when using a Hunter for clean up on the inside of a vessel. I have no problem with the sides but when I get near the bottom I've had catches that ripped two pieces out of the chuck. I'm sure it is something I'm either doing or not doing but is happening when I try to get the very bottom curve. I haven't tried to come across the bottom for a final cut yet.
In the past I normally used Kelton's and have not had a problem in touching the bottom and then rolling into the cut. How is this done with the Hunter or is there something different I should be doing?
