Have a question? Ask Woody!
Tailstock camera mount
Steven Antonucci
steven antonucci
I thought on this issue for a second, and I now have a method of using my tailstock as a secure camera mount. Took about 5 minutes to make from a scrap of color ply.
Start with a rectangle of wood and mount between centers. Turn a #2 morse taper, or as in this case, something vaguely resembling a #2 taper. Make sure it fits snuggly.
Find a bolt that matches your camera mount. Curse because you cut the scrap too thin, and go find two washers. Drill a hole that will allow the bolt to pass through to be screwed into the body. Mount your camera and admire your project.
Get ready for a my "Videos from the tailstock" series... zoom will be achieved by moving the tailstock forward, fine focus by running the handwheel forward or backwards...
S
Re: Tailstock camera mount
Steve Kubien
Suggestion
Steve Kubien
Great idea Steve but a simple solution...find a way to use a retaining rod (you know what I mean right, because I can't remember what it's called). Lathe vibration might rock it loose.
Re: Suggestion
Steve I would find a way to raise it up. Put a board from the lathe bed up to the tailstock and then higher. Then attach the morse taper to this. Per Steve K's suggestion run a cord from the board around the tailstock and back to the board. That should hold everything in place and allow you to get the camera up higher for a better angle. Attach an elbow joint to the top of the board and add another board. Then you could move the camera sideways as well as up and down.
Jerry McCaffrey
Not that you could ever get a catch or a run back from your skew, but I'd still rate that camera in some danger
Re: Tailstock camera mount *LINK*
Even better, get one of the Bogen Articulated arms and Bogen super clamp and you can clamp that to the tailstock and mount the camera to the arm. They also sell a camera platform that fits on top of the articulated arm. These also happen to be really handy for photographing work.
http://www.bhphotovideo.com/c/product/354218-REG/Manfrotto_196AB_2_196AB_2_Articulated_Arm.html
Steven Antonucci
This was meant to be simple
steven antonucci
If you've seen my Youtube videos, you will welcome the next one that is in focus, not waving because I am trying to cut one handed and shoot with the other, and is actually aimed at the thing I am turning.
I kicked around the idea of making something more substantial, but I'm not looking to get into the professional video world. I'm just trying to get two hands on the tool again :)
S
Re: This was meant to be simple
Steve We aplaud your efforts. Just trying to be helpful. :)
Steven Antonucci
Appreciated.
steven antonucci
I looked at the view and I agree that it needs to come up a bit. It would probably also benefit me to have it out of line with the tailstock, so that I could be in the shot as well (I'm gonna be a star!)
Started thinking about disassembling one of those "snake lights" and putting it on a #2 taper with a mounting block. Wonder if they'd be able to support the weight of the camera in any position? Heck, I also wonder if that stupid camera would focus at most distances...
Look what you did... you made me spend more than 5 minutes on it! Now I have to add it to my to-do list! And then reshoot 2 videos... ARRRGGHHHH!
S
Steven Antonucci
Unless u have video proof, it would never happen;)
steven antonucci
Steve Check out how this hollowing system is mounted to the tailstock. I think it would be very easy to adapt to your existing system. It would keep the camera mount from twisting or falling out. That was the basis for the idea I had about adding another board to the top of this with a bolt so it could swivel. Then add a platform for the camera that would tilt and you have a nice camera mount. It would not take any time all to build.
http://www.youtube.com/watch?v=ZrWK0OIeB3w
Nice easy to build boom arm *LINK*
Steve I built one of these out of wood. They work extremely well. The nice thing is it keeps the camera at the same angle. I put an adjustable angle piece on the front of mine because I was using it for lights rather than a camera. I gave it to one of the local photographers who needed a boom arm. Now I need to build another one.
http://wn.com/camera_jib_,_crane_,_arm
