Dye Preview Trick
charlie belden
Having attended a day long demo by Chris Pytlik - mainly on his Signature Dying Process - I'm turning a hollow on which to practice. Now to me, dying a piece seems a real crap shoot, especially if you use Chris's Apply The Dye From The Inside method. I understand how the dye behaves with different grain orientations - in THEORY. But being able to visualize the effect? I can make educated guesses generally about how the dye will behave. But I can't "see" that.
We know that you can wet wood and it'll darken it a bit and show the grain and contrast between side grain and end grain areas. However, water raises the grain and it takes time for the wood to dry after being wetted.
But - alcohol - doesn't raise grain much, penetrates better than water and dries much faster.
Squirted alcohol into my test hollow form, spun it - the alcohol bled through the walls in places I expected - and in places I didn't expect. And places where I thought it would come through - it didn't.
The top row has three views of the dry sanded piece. The bottom row shows the same views - where the alcohol (and later the dye) bled through. A quick, safe and easy way to Preview a dye job.
