What grade of HSS?
What grade of HSS?
What grade of HSS?
Keith Inscho
Just starting to toy with the idea of making my own boring bar and I was wondering what grade of HSS was usually used for the cutters.
Re: What grade of HSS?
Matt Birchfield
I cut, shape and sharpen worn-out planer blades for boring bar CUTTERS (you don't want to make the bar from HSS!). The average discarded planer blade will yield 8-12 cutters, commercial planer blades can be much bigger. I prefer to use the thicker ones, but thin ones work just as well, and are arguably easier to prepare. Buy a cutting wheel made to cut HSS (with markings: A60-OBNA2) for your angle or bench grinder to cut the planer blade into sections and to cut a slot for a set screw... grind to any shape you want on your bench grinder.
Bill Howatt
I don't know what your design for the cutter is but you can make tools using HSS metal-working tool bits. Available in various square sizes 1/8" up and quite inexpensive.
Bill
Matt Birchfield
Every one I make is different, made for a specific purpose. What I was talking about are scraper blades for finishing cuts inside bowls and hollow forms, boxes, etc. I agree with you... HSS tool bit blanks are very inexpensive, and with proper tooling are very easy to make and customize for whatever situation you are facing.
Keith Inscho
I had envisioned a Jamieson or Jordan style bar with a cutter held in with set screws. I can get 3/16" square tool steel in up to three foot lengths, but they come in all different steel compositions made for different things. Since I'm no metallurgist, I just wondered what was the best for what we do.
Re: What grade of HSS? *LINK*
David Walser
Keith,
You want M2 (or better) grade HSS. But, unless the bars you can buy in 3 foot lengths come hardened and tempered, you may be better off buying HSS tool bits. (Most of us don't have the ability to properly harden and temper HSS. High-carbon steel, yes. HSS, no.)
Enco sells 3/16" square HSS tool bits in 2.5" lengths for $0.90. They're available elsewhere at similar prices.
Here's a link:
ENCO 3/16" square HSS tool bit
Lyle Jamieson
Lyle Jamieson
I use and like the M-2 HSS. Why, because it gets sharper and takes a burr better then the harder alloys HSS. Side benefit its cheaper. Down side it will not hold an edge as long as the harder steel but it will be sharper to begin with.
Re: Thanks Everyone!
Keith Inscho
