Fibonacci or Golden Rule Gauge
Bill Jacksonville, NC
How many of you use this piece of gear to figure out your please forms?
Found out you can make your own or buy one from amazon.com for just $1.99
Re: Fibonacci or Golden Rule Gauge
Dave Belser
Bill, I wasn't going to respond because I have a rather negative view of "The Golden Rule". I've never consciously used it to design a piece, granted my work tends to not be classic forms.
I feel that telling people to use the golden rule to create pleasing designs has done as much harm as it has good. It's just one particular ratio that some ancient math/religious fanatics got hung up on. The claim that it occurs everywhere in nature is also overblown. Pick a ratio, I'll find occurrences of approximately that ratio in nature.
There are many ways to make shapes and textures that are aesthetically pleasing. Repetition at different scales for one, dividing into thirds, multiple application of the same ratio, playing with symmetry etc.
My problem is when people are taught to always use the golden rule or told that a piece would be better if they used the golden rule.
I hope you find the gauge useful, but consider it only one of many design tools and don't dismiss your ideas that don't conform.
My 2 cents.
Stuart Johnson
I down loaded the plans years ago and haven't made it up yet. I agree you don't need to always stick to the rules after all it is your wood and your lathe. However, there is nothing wrong with using a pleasing ratio. It would be interesting to make up the jig and then take the measurements on pieces as they when they are posted and compare the comments for those falling close and those that are no where near the Fibonacci numbers.
So finished making a Fibonacci gauge, lengths provided in plans downloaded needed some adjustment. Definitely want to use rivet opposed to nuts and bolts. My masterpiece uses nuts & bolts so not an official Fibonacci gauge yet.
First order of business, measured diameter of an old bowl, and foot everything jived. What about the height of the bowl? Well, next time turn a bowl will keep it mind.
If looking for quick down and dirty eyeball proportions without a lot of math, a Fibonacci gauge nice to have. To say it is a must have just hyperbole!
