sanding Disc
James Pittman
when sanding a bowl with a5" disc holder is it better to have disc with holes or without. I was just wondering what was best. Thanks Jim
sanding Disc
James Pittman
Re: sanding Disc
steve worcester
Theoretically no, because the holes can have proud edges that will add scratches. But, if you use a soft pad, it probably won't matter.
Re: sanding Disc
rjstavran
The holes in discs are there to facilitate dust collection through the sander itself. So unless you are using a palm sander designed for dust collecting on flatter surfaces, the holes are not helpful, and may interfere with the desired finished.
