THE WOODRAT IS BACK!
Newest turning, Shwarz's Cat
Mike Foster
Another minimal surface. This one is the result of finding the minimum surface that joins 6 circles centered on the faces of a cube. I added a stand on the bottom which is a catenoid that is also a minimal surface. This piece was formed almost exclusively on the lathe, with minimal carving to clean up some of the intersections of the curved forms. The challenge with this is turning it on 3 axes with 6 fixings, and getting it thin enough to pierce. It was really a fun exercise in turning. The form is not as elegant as some of the other minimal surfaces I have done, but the challenge of the turning enticed me.
Walnut
Tung oil/varnish mix
6.25"h x 4.5"d
Re: Newest turning, Shwarz's Cat
Steven Antonucci
Between you and Belser
steven antonucci
what are you guys trying to do, leave the fewest atoms?
Perhaps you and David should do a collaboration? If I take a minimal surface object and drill it for more negative space, do I run the risk of creating anti-matter and blowing up the universe?
Stunning as usual, even if I can't get my brain around the minimal surface math.
Steve
Rob Wallace
With apologies to Harrry Caray.......
Rob Wallace
"...........Holey Cow!!"
Oh Yeah?
Dave Belser
It must be the winters up here - I'm working on a fractal sponge. :)
Nice job Mike - we need to get together.
Steve, you're closer than you think
Mike Foster
My name for the piece is really a tongue in cheek reference to the famous physics thought experiment, Schrodinger's Cat. This thought experiment is designed to try to explain/visualize some of the weirdness that exists in quantum physics. My title also refers to the shapes, the main body confined in the cube is called a Shwarz p surface, with a catenoid for the base.
I think you're right
Mike Foster
It's been a long winter, but great for having time in the shop.
A fractal sponge, now that sounds cool. I look at a lot of fractals, but haven't considered doing a piece based on them. Can't wait to see it.
Half alive, half dead...
Jorge Casta�eda
Any radioactivity involved?
;o))
Impressive piece of work Mike, how dd you pierce it?
Thanks
Steven Antonucci
Quantum Physics and Woodturning
steven antonucci
I did a little background reading on Schrodinger's Cat, and I didn't understand the relation? Is it that the piece exists and doesn't exist until I walk into the room to observe it? Do I become entangled with it through observation?
I'm just trying to figure out if you actually made this? :b
S
Sweet!  Very cool.
Greg Haugen
matt overton
Wow! I can almost get my mind around turning the surface, but the piercing is what baffles me!
Re: Quantum Physics and Woodturning
Mike Foster
No relation of the piece to the physics. I was searching for a name and was thinking, Shwarz-Catenoid, or something similar based on the mathematical names for the forms. Something fired (or misfired) in my brain and the idea of Shwarz's Cat hit me. I read books on physics for fun because I find it really quite fascinating and amazing (books that are intended for lay people like me with little of the math that is required to really understand it). So the name is just a nod to my interest in physics and has nothing to do with the piece. Unless it really does turn into anti-particles and wink out of existence.
Mike Foster
No mystery here Matt. I lay-out the pattern on the finished turned surface and pierce with the high speed tools like the NSK (I use dental drills :D ). Looks like it could be done with drills, but there would be significant tear-out on the inside if done like that.
Steven Antonucci
Hawking Books
steven antonucci
I used to read them and I understood all of the math until about chapter 7 or so... and then it would frustrate me to no end that I couldn't comprehend it and just had to think of them as "pretty pictures". I've started most of them 3x and never gotten all of the way through.
I'm going to shock my 12 year old by reading it again. (He thinks I don't read, but I just don't read fiction...)
S
Randy Gleckler
That is just a cool amazing piece. Really like it and like others have said, trying to get my mind around it is 1/2 the fun.
Dennis in Southern Oregon
Mike, you claim to be non-mathematical so how did you come up with the minimum surface solutions? A soap bubble on a wire model?
Dennis
Leo Cuellar
Leo Cuellar
Really nice piece, Mike! Multi-axis pieces are so much fun to do. I certainly wouldn't have the patience to do that much piercing, glad you do though :D
Mike Foster
I have some math background but not enough to speak the language, so to speak. Yes, I have played with wire and soap film, which can give you a good feel for minimal surfaces. Thankfully, there are plenty of mathematicians that like to dabble in art as well so there are a lot of resources available. I have found a couple of programs that will generate minimal surfaces with variable inputs and give you a 3d image of the result. You can also search the web, and there are a lot of images that can be used as a jumping off point to actually produce a piece of art. In doing my research, I have found several other artists working in different media that are based on minimal surfaces. It's a little tougher to do some of these on the lathe, so I really have to pick and choose and figure out what I can actually do on the lathe and how to do it. That's half the fun.
Don Orr
That's just beyond incredible Mike.
Oh, and you read books on Physics for FUN!!! Far out ! :D
