A55 Smoothing Plane
Nova 3000 bearings
Nova 3000 bearings
Nova 3000 bearings
I need to replace the bearings in our clubs Nova 3000 lathe. Anyone know where to get them. I understand they are a common size so i might be able to remove them and find them locally. I won't be near the lathe for a few more weeks. Just thought I'd ask before I get started.
Re: Nova 3000 bearings
Ralph Lindberg
John
I would contact Customer Service (Florida or New Zealand) and get the specs for what you will need to buy, then find a source for them
Jeff Willaford
Most bearings have a manufacturer and part number stamped on the edge of the race. Should be simple to cross-reference once you have that info....IF they are standard bearings.
D. Hansen
John call "Bob" at Teknatool in FL. 1866-748-3025. There was a NZ teck rep there yesterday someone should be able to help. Then contact BOCA Bearing also in Florida they will have the part.
Jorge Casta�eda
John,
When mine went on their 3rd year, I live in boondocks, no way to drag the lathe out, so I bit the bullet and disassemble the head, the one on the pulley came out very easy, the one with the spindle was more challenging but came out too. I took them to a bearing store in a city and they found me equivalents as they did not carry same brand, the original were not sealed, so I did upgrade to sealed ones, they were not expensive and they are still working smooth and quiet.
thanks   bearings are on order, $16.95 each
