EpoxyIssue & Tip
I've been using System 3 epoxy to fill voids for a number of years, but have run into something new. While filling voids with very small cracks in some flatwork boards, I added 5-10% DNA to lower the viscosity and get better penetration [an accepted practice]. What I got was epoxy literally foaming out of the sections with the remainder spongy and worthless. Contacted System 3 and found out that what was happening was that the alcohol was actually boiling [170�] in the mix due to the chemical reaction heat during set. This can also happen with wet wood as the reaction temp can reach 212� so that steam is generated.
If, therefore, anyone here is having issues with porosity in epoxy infilled areas, the steam may be your problem. Remedy is to keep things cool. You get a slower set and cure, but more solid plastic. If you have fine detail to fill, use a prethinned epoxy and/or heat the mix to just warm to thin it out and get it to soak into small spaces. It's also good to put some vacuum on your mixing cup before you pour the mix to get entrapped air out of the liquid.
m
