Progess
Progess
Progess
Dave Belser
Here is yesterdays cube:
I've added another row & column of holes on each face. The cube is still about 1.4" with the number of holes increased from 75 to 108. This makes it much more delicate and transparent. So much so that you can see thought it when looking down the opposite corner axis.
At this point it weighs 8 grams, half as much as the 75 hole version, and 85% of the wood has been removed.
Re: Progess
Rob Wallace
Re: Progess
Rob Wallace
Dave:
Just curious - what species of wood did you choose to use for this project?
Rob
Re: Progess
Re: Progess
Dick Wilson
Don't really know what you are working at but this so interesting that I can't wait to see the finished piece.
Re: Progess
Brad Vietje
Re: Progess
Brad Vietje
Hi Dave,
This is cool! What's the goal -- will you now turn this little cube?
I've played around a little with the negative space inside things, and the intersections of the drilled holes and how they look like vaulted cathedral ceilings... Since I don't have a decent drill press, I've put those ideas on hold for now.
Hope you keep us posted on the evolution of your ideas...
Safe spinning,
Brad Vietje
Newbury, VT
BTW: looks like Tulipwood to me (?)
Re: Progess
Steven Antonucci
Agree on Tulipwood (which is a Dalbergia)
steven antonucci
And I get itchy jus looking at the picture ;)
If you picked a lighter wood, it would probably be 6 grams :)
And it is cool.
S
Re: Progess
Mike Stafford
Re: Agree on Tulipwood (which is a Dalbergia)
Mike Stafford
The sad truth of it is that it might be difficult to develop the same level of detail in other species of wood.
Tulipwood, cocobolo, kingwood, blackwood et al, are all very dense oily hard woods. That is why I like to turn them for boxes (in addition to their beautiful color and grain). Trying to turn a tiny bead on the body under the lid of one of my squat boxes is much easier in a dense exotic. The likelihood of chipout is much greater in most other woods. Of course there are exceptions to every rule.
Re: Progess
Craig Daymon
Holly or Boxwood might be a good choice. Maybe Mopane, though that's probably heavier than Tulip. I think those 3 are on the safe side.
That's what I'd consider if I was trying it. Either way, I look forward to seeing the final piece.
-Craig
P.S. I noticed one of the thin connections broke in the top right most corner, looking at the second picture. I wonder if it would be possible to insert the proper size dowels in the neighboring holes as things get more delicate so there would be support when drilling. Maybe this would help to avoid damage?
Re: Progess
Man, you guys are good
Dave Belser
Yes this happens to be Tulipwood - mostly for the reasons stated. It's dense and oily and works well for this type of work.
There are a few blowouts on this cube, but I think I've solved that problem. I did originally try using dowels to re-fill the holes for support but it only works if the fit is perfect. Then you have the problem of removing all the tight fitting dowel bits.
Generally the little bits all move around and clog things up rather than support and you still have the pain of trying to remove all of the little chewed up bits afterwords.
I've found that with sharp drills and good technique I don't need any supports which is a *BIG* win considering the number of holes I'm shooting for.
As far as where I'm going with this, it will probably end up like Stick Ball or Spherical Aspirations (see davidbelser.com).
Here is another shot I took this morning - nice strong parallel sun light really does the trick with the shadows.
Re: Progess
Keith Tompkins
Re: Man, you guys are good
keith tompkins
Awesome.
Re: Progess
Your mind is more warped than mine
Mike Foster
I've been told that I must be a little nuts, but I think you beat me out. Can't wait to see the results of turning these gems.
Re: Progess
Ed Davidson
Dave,
You might consider filling the drill-holes with casting resin, yielding a colorful matrix like was done on this bottle stopper...
Re: Progess
Keith Tompkins
Re: Your mind is more warped than mine
keith tompkins
Hey Mike, I've been told I'm a whole lot nuts! I think to make things fair, David should TURN each hole on a different center and axis, rather than drill. Maybe it will be done in time for TT? When finished, I think the shadows it creates will be most interesting.
Re: Progess
Steven Antonucci
Yeah, a reverse stepped hole...
steven antonucci
Re: Progess
Actually Keith...
Dave Belser
this was done on my lathe. My machine lathe of course. If I fixed the spindle some how and let the rest of the lathe and cross slide holding the wood spin around the spindle axis - would that satisfy the requirements for this to be a "Multi axis turning"?
Getting power to the lathe might be a bit difficult though. :)
Re: Progess
Re: Actually Keith...
Dave Mount the wood in the headstock of a mill. then you could use the crossfeed with drill mounted in the vise. Then it would be a multi axis turning. :)
Re: Progess
I'd love too
Dave Belser
If you supply the mill!
It's on my list of big metal buys once I'm gainfully employed again.
- Dave
Re: Progess
Less Is More
charlie belden
Your continuing exploration of of positive and negative space keeps getting more in more interesting - if that's possible. At some point you'll begin with nothing and turn solid wood areas into it ; ). Just when I think I know what to expect of your next piece - you surprise me. But the underlying ideas come from the same place - showing us What's There - and - What's Not There - in exceptionally interesting and beautiful ways.
Re: Progess
Keith Tompkins
keith tompkins
qualifies for me! This is going to be a "killer" piece!
Re: Progess
charlie belden
This piece - by itself is very interesting. But when you add its shadow - you get that interesting Negative Space becomes Positive Space - which changes as the piece changes orientation - or the light source moves.
