Pytlik - A Day With A Down To Earth High Wire Act
charlie belden
The show started with a chunk of a willow - from a wood lot - that still had the bark on it, little pencil sized future branches bristling out of it - and the star of the show unable to find his hatchet - or tomahawk - so he used his short stabbing spear to hack them off. Not exactly what I was expecting of the day long demo by Chris Pytlik I attended yesterday. The rest of the day was filled with totally unexpected and amazing surprises that blew away any preconceived notions of how this High Wire Performer creates his signature dye stained pieces - that you�d swear were done by a glass blower - �til you look closely and notice - the obvious wood grain of each piece.
Watching this guy turn that chunk of fire wood into a See Through natural edged bowl was like watching a high wire trapeze artist working at the edge of what may or may not be possible - wet wood streaming off sharp edged tools dancing with the spinning wood. I found myself holding my breath as he made what seemed like impossible cuts - all the while listening to what he was saying as he explained what he was doing and why. And when he wasn�t making impressive cuts - he was sharpening his tools - free hand - sparks flying as he touched up a swept back grind that seemed to sweep back almost to the tool handle (ok - so that�s a bit of an exaggeration - but the gouge shaft was ALMOST 90s to the grinding wheel).
This guy is a turner - who knows his tools, how to make them sharp and shaped to do what he wants to do - and knows how to use them. And judging from the dozen incredible samples of his finished pieces - he knows how to turn beautifully proportioned pieces - mainly incredible hollow forms - that he then works his magic on - with dyes - applied from the INSIDE of the piece. Not only all that - but this man knows and loves wood. �THIS area�s really going to be fun to work with.� - he�d say as he turned that willow, the anticipation in his voice hinting at what�s coming.
With the wet willow piece done and drying, he went to work on a piece of California�s Claro Walnut - turning a small hollow form using a half dozen turning tools - each selected because it does a specific task better than any other tool he�d found. Throughout the turning he was explaining why he was using a specific tool - and fielding questions from his audience. Somehow he was able to answer questions without talking over the head of, or down to, the questioner. And if he sensed that he wasn�t getting the idea acrossed - he�d stop and explain some more - �til the questioner Got It. That�s a rare skill.
But it was the Dyeing part of the demo that blew away my preconceived notions of HOW he achieved the color effects that create his Signature Pieces - that look like they�re a fusion of Chihuly blown glass and Ellsworth obviously wood hollow forms - with a little Jackson Pollock included.
I was expecting secret formulas, a myriad of special brushes, feathers, sponges and graining tools of faux artists. What he USED was:
- four dyes, all of which are readily available TransTint dyes, a �bordeaux� dye from Behlen and a can of acetone.
- little long plastic pipettes with a squeeze bulb on the end and a plastic syringe with a long curved tapered �needle� that you can pick up at most woodworking stores - or hobby shops that cater to RC model plane nuts.
- a small gravity feed air gun
- a plastic Aztec air brush with four drop �cups�
- a regular sized air gun with a small pressurized pot
- a Rattle Can of lacquer
and
- a box of nitrile gloves
- two layers of butcher paper - to protect the table top he worked on.
He had no Eye of Newt or Toe of Frog, no special substance that can only be obtained in a small village deep in the middle of the Amazon. He was playing with stuff you can pick up locally, or, if you live out in the country - you can order it from any number of online suppliers like WoodCraft, Lee Valley or any of the other online stores on the internet.
Starting with a nice bleached almost white hollow form he�d done for the demo, he poured some acetone in a used baby food jar, or added a spoonful to an upside down, cut off aluminum coke can, dripped or squirted some dye in the liquid and was off and running. No careful measuring, no special decanting device, no incredibly fine mesh screen made out of gold filter - just pour, drip or squirt - a little stirring and it was off to the races - all the while he�s explaining that what he�s doing is not Rocket Science - and that ANYONE can do it (not nearly as well as HE does it - but with a lot of playing - one can get close).
Then The Magic began. Sucking up some of one of the colored elixirs into a long necked little pipette with the squeeze bulb on the end - he inserted it into the white hollow form - and squeezed. Moments later - color began to appear on the outside of the bleached white hollow form - and began spreading out. He reloaded the pipette again and repeated the process.
If you�ve ever seen a movie or video of how Jackson Pollock �painted�, you�ll have an idea of Chris�s process. Initially it looks like he�s just squirting dye in the piece and the dye is just bleeding through the walls of the piece in a totally random, chaotic way. But remember, this guy knows wood - and that it�s made up of �soda straws� that make up it�s grain. And the ends of those �soda straws� will soak up a lot more of a liquid - and the color of it - than will the sides of the soda straws. He�s �popping the grain� the end grain darkening far more than the side grain. He�s kicked up the contrast between the end and side grain in the hollow form.
Over the next few hours he showed his audience how he exploits his mediums - acetone, dyes - and the wood he�s playing with - adding color here, blending colors there, bleeding this color into that one, rinsing out some color here, darkening an area there. It reminded me of watching a water color artist who knew his/her medium work - or a glass blower. It was spell binding to watch the work develop, listening all the while to his down to earth description of what he was doing and why. And he could answer questions while working his magic.
The last part of Chris Pytlik�s demo was how he gets his glass like mirror finish. Like the rest of his demo, he revealed and explained his process - again - none of which is Rocket Science - and all within the capabilities of you and I - if we want to spend the time - and do it right. And though he uses air guns to apply his lacquer, he can get the same finish - with a Rattle Can.
Like the down to earth guy this High Wire artist is - he was sort of embarrassed at the applause at the end of his demo. Fitting for a guy who has a tomahawk - and a short stabbing spear he says is really his favorite scraper.
If you get a chance to see this man�s High Wire Act - I highly recommend that you buy a ticket and see The Show. For a $30 admission price, including a free lunch - the show is one you won�t forget - and you just may pick up some acetone, some TransTint and Behlen dyes, and some little plastic squeeze tip pipettes.
