Veritas - Innovation in Tools
Here we go again.....
Dave Belser
About 1 1/2 on each side, 25 wholes/side, 75 total.
Just getting started with this idea and this is just a study to see if I can drill the holes.
Re: Here we go again.....
So how yah going to turn that???
Galen Vetterick
The same way I turned my other sparse matrixes
Dave Belser
I'm still stumped on the stick ball!
Galen Vetterick
Keith Tompkins
keith tompkins
Lemme' see....alternate black and white "dowels", glue in place, and turn?
Dave Belser
I actually managed to get this done with no extra supports. Drill the two side faces first and then the end grain. To turn it I'll probably fill it with wax first.
The cool part is this only took a few hours instead of a few days. So at the scale I want to work at it should be days instead of weeks.
- Dave
Steven Antonucci
You call that challenging?
steven antonucci
C'mon Dave... you can do better that that!
I want to see you produce the thing you drilled out (intersecting rods), turned into a hollow sphere with a cube inside.
That ought to keep you busy for a bit...:)
S
No problem....
Dave Belser
And I'll make the rods out of rice or spaghetti.
OK, not sure about the cube inside but rods are definitely a cool idea.
Thanks.
Steven Antonucci
Cool idea, but cause you a brain-ache!
steven antonucci
I thought about it for about 5 minutes and I couldn't think of any way to produce it in one solid piece of wood. You could potentially figure it out with other media and other non-lathe processes (pretty simply, I think), but wood made my brain ache...
S
