New pen from my shop
Andy Lincoln,in Dearborn MI
I created a new pen recently,not only to try some different ideas I have seen on the web but to also continue to practice the photography aspect as well.The upper portion of the pen shaft was poplar on a 7mm brass tube,turned down to just below standard bushing size.The stamps were applied to the poplar using craft glue,.After drying several coats of Mod Podge� Gloss sealer was applied I sanded as I needed between coats,what ever I felt was necessary.After the build-ups of Mod Podge� were finalized and allowed to dry overnight ,I lightly sanded with MicroMesh� and then applied BLO/CA as a finish which was then sanded with the MicroMesh�
The camera used today was a Canon Sx20is 12.1 mp.I adjusted the color settings to vivid,macro mode on,wb adjusted to a custom level.Image Stabilization was turned off and the camera was placed on a tripod.The photos were then manipulated/adjusted further with Photoshop 7.0.Each pen is not only a new challenge,new lesson,new method it gives me a chance to try and improve the photo skills as well.
The lower shaft of the pen is walnut which has been ebonized with a vinegar/steel wool solution prior to applying the BLO/CA.The metallic hardware is in a gun metal finish.
The photo tutorial I have been reading can be found here.
The idea for the pen came from a tutorial on the IAP website.
That tutorial can be found here
I apologize in advance if someone objects or this breaks rules by linking to another forum.
I just do not want anyone to think I am claiming this as an original idea/design,etc.
I am not set up to cast polyester resin so my pen is simply finished in multiple coats of CA.
Thanks for looking,
Andy
