I have a question for the toolmakers out there.Is there any value/desire/etc. for aluminum tubing to make into tool handles?I have about 150 ft +/- of 1.375" OD x0.125" wall x 1.125"ID tubing in lengths from 3ft to 6ft.It was part of a custom built hospitality tent from Ford Motor Co. in the 1960's.
My family used it on weekends in a fishing camp for a few years before we purchased a camper,and later a cabin on a lake.I have had the tubing stored in my shop for at least 6 years now,intending to have a use for it someday.With the advent of many new turning tools I wonder if it can be re-purposed?
I suppose you could obtain some solid aluminum rod at 1.125" OD to drill out a centered main hole to fit the turning tool shanks (1/4", 3/8", 1/2", 5/8", etc.) and then drill and tap two holes for set (grub) screws to hold-onto the tool shank The solid sleeve would then fit into your tubing which would also get drilled and tapped for set screws to hold the solid insert. (You would get a few fine threads into a 1/4" wall thickness to work OK.) It would also be possible to make a plug for the other end of the same 1.125" OD material, and then you would be able to add metal shot to the handle's cavity to dampen vibration. Might possibly make a nice handle, although for my small hands, it might be a bit "chubby" to be comfortable for me, especially if you add any grip material. YMMV....
I have made some inexpensive handles out of solid 1" 6061 aluminum rod that's drilled and tapped appropriately, and I then use replacement black foam rubber bicycle grips over the outside of the 1" OD solid aluminum handles as cushioning and thermal insulation on these handles - I made about 6 or so handles so far, and they work great.
I don't know why your tubing couldn't work similarly if you made the proper insert to hold the shank of a turning tool.
Sounds like a great way to spend an evening making some custom tool handles from stock you already own. Go for it and let us see what you make!
I have made quite a number of handles from aluminum tubing and love them. I used 1.25" diameter tubing and slid a piece of flexible water hose (clear braided) on it like a Oneway handle. That made it 1.5 inches in diameter -- which is perfect for larger tools like 5/8 inch bowl gouges and 1 1/4" spindle roughing gouges. With these tools you really need a larger handle than standard to get a proper grip and stop the tool from torquing in your hand. You may have trouble getting plastic tubing to fit on the size of aluminum tubing you have -- but you do not really need it. It just makes the tool warmer in a Canadian winter climate and more pleasant to hold. The larger tool handle did wonders for the cramps I used to get in my hands after roughing bowls. Now I don't get any cramps. These handles are also great for people who suffer from arthritis.
You can probably find a block of aluminum at your local junk yard large enough to use for the solid sleeve to hold the tool. It can be turned on a wood lathe using regular tools. Cut the sleeve about 3 inches long, and use 1.5 inches for the exposed part where the grub screws fit. Machine down the other 1.5 inches so it just barely fits in your tube. Coat this section with FLEXIBLE CA glue (I would not trust the regular stuff) and drive it into the tube. It will not come apart. I have been using some of these handles for eight years now with no difficulty. I got lazy and just turned a piece of Cocobolo to plug the back end. But you could use another piece of aluminum. I suggest that if you don't use the clear water pipe on the handle that you sand it with 80 grit sandpaper. It will have a nice matt appearance and will give you a great grip.
