Life's lesson # 243
Life's lesson # 243
Life's lesson # 243
Scott Hurley in N VA
Never use Anchorseal on a roughed-out bowl blank that has a bark inclusion. Now I can't seem to get it out of the little crevasses in the bark. I've tried mineral spirits and a hair dryer (not together), and a dental pick, but I still can't seem to get it out. Does anyone have any suggestions? Thanks.
Scott
Re: Life's lesson # 243
Jim in Burlington Ont.
Lemonade
Jim in River Oaks, Ont.
Thinking , "What will dissolve Anchor-seal" Maybe gentle heat? (hair dryer etc).
Sand blasting also comes to mind, but it might be a "lemon Problem" now, perhaps lemonade has become an option, you might think of using it as a design enhancement opportunity?
Take care.
Jim
Anchorseal is a wax emulsion. The water dries leaving the wax coating behind. It also leaves the emulsifier behind.
You can remove the remaining Anchorseal by running the surface under hot water. The wax will just rinse away.
Note: Do not use regular Anchorseal on wood that will be rained on. A couple of good soakings and the "sealer" is gone.
woodspinner
Mark is right, water will get it out. If there's any left I use a battery powered tooth brush works great for getting wax out of bark and any other rough spots been doing it for about 10 years now.My NEW one is Buzz Lightyear now he has some power.$5.99 at Wally World.
Thanks for the quick answers. I'll try the hot water, and probably an electric toothbrush.
Scott
