Sanding Drill Problem
Stuart Johnson
The other day I was power sanding with a Milwaukee right angle drill. I blow the dust off with compressed air (about 90 lbs maybe more) between coats. I decided to give the drill a squirt or two and blow out the dust. The drill no longer works. For all that happens it might just as well be unplugged.
I've taken it apart and all looks okay. There are no loose wires and the brushes look to be fine. Any ideas about what happened, how to trace the problem or fixes?
Re: Sanding Drill Problem
Steven Antonucci
Have you checked the switch?
steven antonucci
My first, best guess would be that you blew dust into the switch, and that it can no longer make an electrical connection. If you can pull it out, a meter will confirm this.
S
Peter Charles Fagg (UK)
My sander went haywire after I had applied a vacuum cleaner nozzle to it, I had to remove the brushes and clean the commutator before it worked again! (I used Methylated Spirits, don't know if that is available in the USA)
Might help, regards Peter.
bill Crommett
That is why I buy a $30.00 throw-away from Big Lots for sanding. They have the quality I require --- they run until they stop.
Thanks the switch was it or
Stuart Johnson
the electric gods took pity on me. I couldn't tell what the switch was doing but in the process of messing with it and blowing out any dust that might be in there I disconnected a couple wire and reconnected them when I put it back together. The switch itself is pretty sealed so I don't know what fixed the problem but it's running.
Steven Antonucci
Assumed it was electrical
steven antonucci
I have a second switch on my lathe that often clogs with dust. I don't know how it gets in there, but it does. Took me days to figure it out, so now I assume that every "dead" device is because there is dust insulating current somewhere...
Glad it's fixed.
S
woodspinner
Got a right-angle from Harbor Freight 2 years ago it's slow speed and does wonders as a sanding drill.
Paid $19.95 and it had a 90 day warranty can't beat that.
Barry
The price of Harbor Freight's right-angle drills is now inflated to $29.95 and $39.95. The higher priced model has a keyless chuck. Both appear to have decent quality. I looked at a Milwaukee right-angle recently and was not impressed with the quality. I say buy the cheap throwaways and run 'em 'til they quit, then toss 'em.
