Turning Captured Rings
Charlie Anderson
I've got a couple of nieces getting married this year and I've decided to do wedding goblets for both.
I've never turned a captured ring. So I bought a captured ring tool. (cue Steve A to say it's easy to make the tool. :-)) I got a 1/4" tool but wish I had gotten the 3/8"
Anyway, I've now turned somewhere around 7 or 8 rings and have one problem. They almost all have 'bumps' on them going paralleling the circumference. How do I avoid that.
Also, the tool has a flat end about 1/16". It caused me to end up with a ribbon of wood after the ring is freed.
I've thought about grinding one of my small hollowing tools cutter to a point and just replace the cutter later. I could use the point to make the final cut to free the ring. And I guess I could grind the ring tool to a point as well.
Ideas? Thoughts?
Re: Turning Captured Rings
Steven Antonucci
Funny, my homemade one doesn't do that?
steven antonucci
I think I know what you are saying. I made mine so that it requires some finesse to cut the ring free. It's not round on the end. I doubt I could get a clean cut all the way around on a half circle. One the ring is free, I wrap the stem with abrasives and gently sand the ring interior.
Mine took about 30 seconds to make on the corner of the grinding wheel.
If you look at the bottom of this goblet, all three rings were cut with it, but I decided that they looked stupid, so I cut two of them off and just left the one.
I spent $5 on this tool about 15 years ago, and finally found a use for it.
Steve
What a pithy!!
Jorge Casta�eda
To have that void in the stem, nice piece... :D, sorry I could not help myself.
15 years turning, wow, I am starting my 7th year.
Steven Antonucci
The stem is hollow
steven antonucci
I couldn't do it if I tried, so I suspect that it's more just dumb luck than anything else, but the pith ran almost the entire length of the stem and if you angle it right, you can look through the cup through the stem and out the base.
S
Fred Holder
Hello Charlie,
I don't know which captive ring tool you purchased. I use the Robert Sorby Set. I use the beading tool to shape the top of the ring. I then use the right hand tool to cut in part way. Then the left hand tool to cut the ring free. If one is very careful, it will cut the ring free without leaving a rough area on the bottom of the ring. I have the 1/4 inch and the 3/8 inch set. For wedding goblets and baby rattles, I use the 1/4 inch set. It works best with a fairly dense wood such as cherry or other fruit woods.
Good luck.
Charlie Anderson
My tool is a Packard tool.
The wood probably is at least part of the problem. I've turned three goblets for practice and they were all from dry silver maple. And I had plenty of tearout, especially when I tried to put detail on the stem. When I get back to turning next week, I'll start with a piece of cherry.
Thanks
Jorge Casta�eda
Charlie,
Silver maple is a weed tree, grows too fast. Find another wood with tight growth rings and you will have better results, and like everything else, practice, practice. Try making captive rings just with the skew, they will be different, but it can be done and you will learn a little about how the wood wants to be cut.
