Re: Make your Own! How?
Jorge Casta�eda
Henry,
The main gear is a torch and and arc welder, plus a bench vise, hack saw or mechanical equivalent, wire brushes, files or hand held grinders,
For the original tool rests, we had a set of rollers, put a length of 1/2" x 1 1/2" flat bar crank the rollers and out of the other side a curved piece comes, shape as desired and weld to a round bar the proper size for your banjo, 1" for the Powermatic or Nova.
Without the rollers, we must heat up the bar to a dull red and forge it to shape, or use a thick metal plate with holes on it and insert pins on the holes and bend the heated piece around the pins, like my friend the welder did.
the metal I got from the scrap pile in the shipyard near by.
Pictures in a couple hours...
